Question about Philips Magnavox MWD200G DVD Player
No picture or sound magnavox mwd200g dvd player
When I hook up the red, yellow and white connections to my satellite box, I still do not get a picture or sound.  What am I doing wrong?  Out from the dvd player, in to the satellite box.  All of the connections are correct.  Still no sound or picture.
    Scholar:
  • 85 Answers
On the side of the tv mostly there is a button for dvd mode you will have to press that button to reach in dvd mode.if no such button then its the cables fault or the wires are not connected properly just check out this link for connections
For tv/dvd /vcr connections
http://www.funai-corp.com/support/setup.aspx?prod=dvd2tv2vcr
For tv/dvd /vcr question answers.
http://www.dvddemystified.com/dvdfaq.html#1.27
Posted on Mar 02, 2009
Why can I only get a black and white picture? the unite came with white, yellow and red cables and the back of my Hi-Def Sony T.V has white, red, blue and green. Audio is working great, I had to plug the...
how many aux inputs does your tv have?(vid1,vid2 etc.)there must be a set of component inputs you can use to hook up your player. Another thing you can do is to hook up your player using the S-Video connector if one is provided on both devices(you will need the cable for s-vid).
Dec 30, 2009 | Philips Magnavox MWD200G DVD Player
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Help Me!
My tv has several video inputs & this is the way I did mine. I ran the red,white & yellow cable from the dish box to "video 1" on the tv. For the Magnavox I ran a coax cable from the dish receiver out to the rear of the Magnavox & the red,white,yellow from the magnavox to the tv "video 2". Check the dish box to see if the switch in the back reads channel 3 or 4 & set your magnavox to the same. Make sure in the setup you have it set to rear connections. If you have picture on both video settings on the tv everything is golden. Hope this helps.
Mar 24, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I get sound recording but no video when using my magnavox dvd rec
You have to use a red, white, and yellow connection, or a red, white and s-video connection.
Two possibilities:
1) Connect a yellow composite A/V cable (or an S-video cable, if you prefer) from the video or monitor OUT of your cable or satellite box.
OR:
2) Connect a yellow composite A/V cable (or an S-video cable, if you prefer) from the video or monitor OUT of your TV (many TV's don't have such a thing).
Try recording again - it should work this time.
-Tha Mp3 Doctor
Feb 20, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I hook up the mwr10d6 and set up to record from cable dvr or vcr? I play dvds ok when i try to record it was all scrambled like i might have hooked it up wrong somehow. Do not have instruction...
Here is a link to the manual, but it is a little dense:
http://www.funai-corp.com/6pdf/om/MWR10D6.pdf
Now that the digital conversion is imminent, nothing will ever be simple again.
This is not the ONLY way to record with this machine, but here is one way: (I'm also assuming that you have a cable or satellite BOX - if you don't, let me know):
1. Connect a red, white, and yellow cable from a red/white/yellow OUT of your cable or satellite box to the Video IN and Audio IN of the Magnavox.
2. Connect a second red, white, and yellow cable from the Video and Audio OUT of the Magnavox to a red/white/yellow IN of your TV (most TV's only have INs and not OUTs, hence they may be unmarked either way - but this situation is rapidly changing).
3. Change your TV to the channel that corresponds to the red/white/yellow port - some TV's label it "AV1," "AV2" etc. - others label it "Video1", "Aux 1" etc. - I would have to know the exact model # of your TV to be sure.
4. As long as you can see the channel that you are trying to record on the TV screen, you can just press REC on the Magnavox with a blank DVD inserted.
Like I said, this is not the ONLY way, but it is probably the simplest.
-Tha Mp3 Doctor
Feb 02, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I need help! Our cable jack on our tv is messed up so we have to run it through a dvd/vhs player. I have tried everything to get it to work. I can play dvds and see them, but i cant get the satellite to...
Change the source on the Philips/Magnavox to switch between satellite and movies (warning: this particular Philips/Mag cannot process HD Satellite receiver boxes). You can switch sources by using the Magnavox remote and pressing 0-2. Then press ch down until the display says either L1 or L2 - whichever input the satellite is connected to. Another warning: For my instructions to work, you must have a non-HD satellite receiver, and you must run a red, white and yellow cable from the satellite box to the Magnavox instead of a standard coaxial cable wire (and then, of course, run a second set of red, white and yellow cables from the Magnavox to your TV).
-Tha Mp3 Doctor
Dec 31, 2008 | Philips Magnavox DVD/VCR Dual Player
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Audio out problem (magnavox MWD200G)
yellow to yellow that is video and that is ok.
red and white are the audio chanels left and rigt try to change it and your soun will be ok
Feb 07, 2008 | Philips Magnavox MWD200G DVD Player
Hooking up a magnavox MWD7006 DVD player to a APEX TV
honey and guest: connections: Red, white, and yellow composite from out of cable/sat box to in of this dvd, and then a 2nd red , white and yellow cable from out of this player to in on television. Every television calls the correct channel something different - make note of where you plug the r,y,w cables to TV -- it may be labelled video1, video 2, av1, av2, input1, ext 1, etc. Turn tv to correct input/av/source/video channel. Call 1-800-605-8610 for further assistance.
Jan 13, 2008 | Philips Magnavox MWD7006 DVD Player
Philips Magnavox MWD200G DVD Player Logo
343 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
