Question about Panasonic Televison & Video
My panasonic tv shut off and I cant open it anymore
My tv shut off and I tried many times to turn it on but it didnt open and there is no power. What will I do?
    Scholar:
  • 85 Answers
In the tv on the main circuit board there is a small fuse located that fuse blows out .due to which the power inthe tv does not come replace the fuse.it will cost you under $1 for new fuse.then it will work.
Posted on Mar 02, 2009
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
I have a 2008 46 inch Panasonic Plasma. Whenever I try to turn on the tv within an hour of turning it off, the tv doesn't turn back on and the power light blinks. To get the tv to turn on I h
I will be the barer of bad news. your Panel is failing. Plasma TVs are only made to last 5-7 years. 10-12 is more realistic from what I have seen. The TH46pz85u is a great model of TV but when that starts happening it means the panel is beginning to fail. Replacing the panel is cost prohibitive and they don't even make them anymore.
You will be wise to spend your money on a new TV. newer TV's are much more power efficient as well. your 46" TV draws a lot of electricity. Your TV draws almost 650Watts of power. A comparably sized TV today(55" or larger) Draws around 200 watts. Significantly less.
Jan 10, 2018 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic th-50pz800u shuts down and i can not turn back on, red light flashing 2 times, sometimes 10 times
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 20, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
I turn the tv on--it turns off--turn it on again--shuts off again. What is my problem?
Power supply board have problems.It not giving the wright voltages to the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 19, 2010 | Panasonic Televison & Video
50" lg plasma tv when i turn it on it shuts down in a few sec after doing this several times it will eventually stay on what can i do
The power supply board have problems,it not giving the tv the right votage anymore.That why it shutting down,not sustancening power to the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power board for the replacement.
Oct 16, 2010 | LG 50PC3D 50 in. Plasma Television
Just replaced convergence chips for Panasonic rear projection tv. Now when turned I turn the tv on, it turns off and blinks 3 times (the LED light)....what do I do???? They were the correct chips....
Go back recheck ICs make sure you didnt forget to solder some of the Pins. Ch small blue capacitor next to hori output Transistor 2k volts,make sure it is OK,then resolder all the yoke plugins. Let me know if you need anymore help.
Mar 25, 2010 | Panasonic PT-53WX53 53" Rear Projection...
TV shut off and cannot turn back on
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.The part # for your lamp is TYLA1000 you can find it here:http://www.discount-merchant.com/Panasonic-TY-LA1000-Lamp-DLP-TV-bare-lamp-p/panasonic-ty-la1000-lamp.htm Good luck and God bless you!
Feb 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Brief power on then shuts off
It could be a component short or crack on the power supply board. Open the back of the TV and look for signs of defect. The power supply board is the brown one on the right with huge capacitors.
Jul 12, 2008 | Panasonic PT-61HX41 61" Rear Projection...
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Tv wont turn
replace the AC fuse, a GMA 6.3 amp fuse. I have seen many of these sets where the AC fuse opens for no apparent reason.
Jun 18, 2007 | Panasonic CT-36HL43 36" TV
Televison & Video Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
