You need only to find the correct software and driver for your webcam. just go to google.com and type support acer. you will see all the list of the site from the acer company with there drivers and downloads. just make sure that you install the correct driver fitting from your windows. if you install windows x86(32bit) you must install also the 32bit driver suyin, bison or acer crystal eye. this things works for me. im an IT guy here in qatar microsoft and willing to help and solve your problem
Go to the ASUS WEB site to download the device drivers that are installed on your computer. Download the Windows XP or Vista drivers for your model computer.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Get online
and got to www.google.com In the google search box type: "Acer
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Webcam rivers.
Try using ManyCam.
You can always download Manycam and install it. Go to www.google.com and in the search box type: "download.cnet.com" (without the quotes). Click on the link to go to the site. When the site opens look down on the left and you will see a gray area that says Find Software. Type "Manycam" (without the quotes) in the white search area then hit the search mirror. When it brings back your results look for the one that says ManyCam Virtual Webcam. Down load it and install it. Make sure you remove the check box on any junky programs it would like to install. You only want to install ManyCam, no additions whatsoever during the install. ManyCam is totally FREE and easy to use, and you will always know where your webcam software is.
Get online
system when requested. Download and install the Web cam drivers.
Try using ManyCam. It comes with drivers and software.
Get online
system when requested. Download and install the Webcam drivers.
You can also try using ManyCam. It comes with drivers and software.
You can also visit ManyCam's website at http://www.manycam.com for instructions on using it with skype and other applications.
Get online
You can also try Manycam. It has it's own driver and software application.
Once you get the ManyCam installed and running you
can go to their website and read up on how to set it as the software to
use when you make video calls. In fact once you install it, your
software that came with the Acer Laptop might start working.
