Question about Aiwa Z-R555 Shelf System
I own an Aiwa Z-R555 stereo and I'm having trouble
I own an Aiwa Z-R555 stereo - trouble with the left audio cassette drive
My problem is that the 'play' and 'record' button next to it are bent and no longer mechanically able to engage that drive. Thus, I cannot make copies of cassettes, CD's, records or from the radio.
Does anyone have instructions for dissasembling/repairing the cassette player, and where I might find replacement parts?
Very grateful for any help!
-Bruce Costello
5 Suggested Answers
  • 135 Answers
SOURCE: Aiwa NSX-V70 Cassette deck Belt?
http://www.donberg.ie/warehs/groupba.htm
try here
Posted on Jan 18, 2009
  • 4 Answers
SOURCE: Need to record daughter playing musical instrument
use an mp3 player than you can store it on your computer and mmake a cd of it.
Posted on Mar 20, 2009
SOURCE: aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Posted on Apr 20, 2009
hardrocko
  • 1476 Answers
SOURCE: I have a Aiwa stereo system that has a turn table,
fullmoon5220,
You need to replace the belts and clean all the moving parts. If you look at the rear of the unit you should see about 6 to 9 recessed holes. They have screws that you need to take out to take the unit apart. Remember to unplug the unit first. There could be more screws and even a couple on the front under the cassette doors. Every unit is different and you will just need to be careful and not force anything.
Once the unit is in two halves you should see the belts. Measure the belts with a ruler for length, and go on the short side because they will be streched. Go to http://www.mcmelectronicsinc.com where you should be able to match up the belts. Also order some contact cleaner to clean the capstan, rollers and heads. In addition get some lint free Q-tips to clean all the parts.
Use the cleaner on the capstan, pinch roller and the load mechanism. Install the new belts and reassemble the unit. If this was the only problem you should have a working unit.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Mar 06, 2011
  • 6771 Answers
SOURCE: aiwa cx_na77 stereo wont play cassette tapes
The cassette belts are bad, or the motor is not running.
Posted on May 28, 2012
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
Aiwa cx_na77 stereo wont play cassette tapes
May 28, 2012 | Aiwa Audio Players & Recorders
I have a compact disc stereo cassette receiver and the cassette wont work
It can be any number of reasons, bad belts, "common issue" cassette motor not working or gear problems.
Apr 27, 2012 | Aiwa Audio Players & Recorders
Can music be transferred to computer and then be burned to cd
(Yes) What do you mean by transferred to computer? A stream (music play like a radio) a Download (a file saved to your computer) to record a stream to a audio cd recorder is easy. You need a cable with a 3.5m plug one end and 2 RCA plugs on the other end (red and white plug) Use the plug that looks like a headphone plug, plug that into the computer headphone or speakers and the others into your stereo red into the red hole and white into the white hole choose (AUX) now play the music from your pc you should hear it playing out from your stereo. Your all set. (have fun)
A download: A music file is stored on your computer. When you choose to download a file always remember what folder it is in! for a mp3 file you can use windows media player to burn cd. (must have a CD or DVD Burner installed in your computer to do this) if not don't fret just see above it will also work on downloaded music.
Feb 05, 2010 | Aiwa Z-R555 Shelf System
Have Aiwa NSX-V9090 Stereo with jammed cassette. I removed the cassette; however the system still thinks it's in there? When I power up the system it tries to play the tape the stops. I am not able to load...
Check with a small torch, to ensure that there is no tape broken arround the pinch roller or head, if there was no tape broken away, between the pinch roller and the cassette head there is a white cassette bar, this may have become bent.
Aug 08, 2009 | Aiwa HS-TX426 Personal Cassette Player
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
Aiwa Z-R555 Shelf System Logo
56 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
