Question about LG LMV1314 Microwave Oven
Burnt package of vegetables in my microwave
Cut corner off package of vegetables as instructed by Woolworths and put in microwave. Probably left in too long as the package began to literally burn in flames and a big piece of plastic came off the door inside.
Is there any way I can replace the piece that came off the door inside because when I try to clean the microwave the liquid goes straight through to the glass.
I forget what my model is by my microwave is an LG 20 litre.
Many thanks
Desiree
  • LG Master
  • 9,098 Answers
You will need your full model number from the tag on the unit.
You can order parts from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Posted on Mar 06, 2009
Will I have ruined the microwave if I forgot to put the food in the oven and made it cut out?
Its possible you could have burnt it out. You also may have blown the fuse which should be inside the cabinet. Before you do anything get a container of water and try to heat it and see if the machine works.
The microwave may have to reset itself. If it appears to work I would use it. If it shuts itself off then you have a problem but its probably cheaper to get a new one than to repair.
Dec 17, 2016 | In Microwave Ovens
Is the mica cover crucial?
sad to say but YES it is critical . .
Mar 25, 2015 | In Microwave Ovens
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
When I turn on the microwave for cooking, a fuse 20amp burnt, then i replaced the fuse and set it for cooking and the fuse 20amp. burnt again,
okay this means that your microwave is having a short problem check the varistor across the primary winding of the low voltage transformer probably it is burnt that cause it to short or it is shorted without sign..cut away varistor from the connection and put in a fuss then see what it does.good luck.
Sep 13, 2011 | Microwave Ovens
Are all vegetables can be transform into juice?please give me instructions how.
Yes. But the quantity depends on the vegetable's juice contents. Use a juicer to extract the respective juices of vegetables.
May 05, 2011 | Microwave Ovens
I havent used this microwave before. Can you please give me step by instructions on how to cook a roast beef and vegetables
If this microwave is a convection oven, you don't give make or model, treat as a fan assisted oven. 20 minutes per pound and 20 minutes extra for the meat, veg is best microwaved for a few minutes except potatoes, put them in the dish with the meat. Cover to stop splashing and set temperature to 190 Celcius 370 in proper temperature.
I am getting hungry now!
Enjoy.
Feb 28, 2011 | Microwave Ovens
Sparks, noise and burning smell
If it is burning and arcing at the antenna, it is probably arcing in the wave guide area. Probably will have to replace unit. I have had some success by removing the antenna, sanding and repainting the burnt areas of the cavity and sanding off any burnt marks on the antenna. Need to look at top of mag to see if also arcing there too.
Jun 16, 2017 | Panasonic NN-2555A Microwave Oven
Microwave Turns on automatically
I would remove the plug from the mains for at least one hour. This should remove any memory
Jul 04, 2007 | GE JVM1440 Microwave Oven
LG LMV1314 Microwave Oven Logo
81 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
