Question about Vizio GV42L 42 in. LCD Television
Green line running down left side of TV
We have an almost two year old Vizio GV42L LCD TV with a green line running vertically down the left side of the display. It appears after the TV has been on a few minutes. HELP, I am going cross eyed!
  • 87 Answers
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Posted on Oct 23, 2007
SOURCE: green screen vizio lcd
My 37" vizio I bought in Dec 2007 did this (green screen at start-up on all inputs). At first it went away by itself after you left the unit on for 15 minutes, but then 2 days later the whole thing DIED. Luckily Costco has a 90 day return policy on TVs.
Vizio tech support suggested this (before it died that is):
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD.
Posted on Jan 09, 2008
  • 10 Answers
SOURCE: Vizio GV42L 42inch LCD/HDTV
there are several possibilities. first if the unit comes on and the "VIZIO" light turns white, but no picture or sound, then the main control board is most likely the issue. could be the LCD control board(s) depending on model one or two. and ultimately could be the power supply on the upper side....if the "VIZIO" light does NOT turn white, the whole power supply unit is out. after that, would have to scope the circuits to find out. Seems that the control board is the most common and tends to happen on many different sizes. new board will be around $350.00. Might get lucky and find a used one, but it MUST be EXACT part or it wont work right. if you dont find one or want to sell yours for parts, id be interested in the screen. can reach me at kmarlin@grandvalleygolfclub.com. thanks, keith
Posted on Aug 10, 2009
xCAUSALITYx
  • 210 Answers
SOURCE: vertical black lines in samsung lcd tv
Hardware related, needs an engineer as not a simple fix.
Thanks
Posted on Sep 05, 2009
SOURCE: I need help with disassembly of Vizio GV42L LCD TV
remove all the screws and start at the bottom and push in the tabs, and work around the edges, being careful not to pry too hard, the cover has clips all around the tv. after the bottom is free and one of the corners the cover will kind of pop off if you use the palm of your hand and lightly tap as you apply sum upward pressure.
Posted on Dec 06, 2009
Vizio VW46LFHDTV10A vertical lines on either side of the screen. I tapped screen and left side lines disappeared.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Vizio VW46LFHDTV10A 46 in. LCD TV
How to fix green vertical line on 60" vizio led smart tv
I had a similiar problem on a Sony , vertical line or lines on the left side of the screen. It was the driver board for the LCD. Good Luck
Mar 17, 2014 | Televison & Video
My Vizio TV (less than 1 year old) has green/red vertical lines on the left side when first turned on. They go away in 10-20 minutes.
Hello. If your POP (Proof of Purchase like store receipt) is less than 1 year old you have to contact Vizio immideately and setup appointment for authorized technician in-home service.
You might have problem with LCD Panel (or plasma whatever you have) that result of manufacturing defect and reveals itself only after several months of use. You still covered by manufacturer's warranty and you don't need to pay anything to get your TV fixed or replaced.
After warranty expiration replacing a panel generally cost more than buying new TV.
Act as soon as you can and don't try to fix anything by yourself.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
Screen turns green after 20 minutes of use
static line at top is a problem with the broadcast input. many cable boxes and satellites create this because they dont quite fill the true resolution that the tv is capable of. the green splotches sound like overheating of the lcd lamps. id return it for a new one.
Jul 01, 2009 | Vizio GV42L 42 in. LCD Television
Right half of the screen mostly green and red with vertical strip
It sound like there is a problem with the mainboard. What is the model number of the TV?
Feb 05, 2009 | Vizio GV42L 42 in. LCD Television
Toshiba 19inch lcd tv green line down screen
A solid line down or across the screen is due to problems in the display itself. Unfortunately, there's no way to repair it because the bad circuitry is integrated into the display. The only cure is display replacement.
Not the solution you want, but that's how it is. (With the huge number of transistors that are part of the display, it's actually amazing there are as few failures as there are.)
Jan 22, 2009 | Vizio GV42L 42 in. LCD Television
Green line down the left side
try changing the resolution to 720. You'll need to do this from either your cable box or your direct tv receiver and not from the tv. Hope this helps. Let me know how you make out. don_mendez@hotmail.com
Jan 18, 2009 | Vizio GV42L 42 in. LCD Television
Vizio p50 hdm
Sounds like a bad power supply. I have a GV42L 42" manufactured in march 2007. It works perfect except the screen has a fracture on it. The warranty is voided because we damaged the screen. I can sell this to somone who has a good screen but needs boards or speakers, etc. Or I will buy your tv that has a good screen but damaged boards in it.
camckay7626@yahoo.com
Aug 13, 2008 | Vizio GV42L 42 in. LCD Television
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Vizio GV42L 42 in. LCD Television Logo
210 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
