Question about HP Pavilion F1523 15" LCD Monitor
Menu pop up and menu keys do not work
My HP Monitor HP 7540 pop up menu and does not disappear . also the keys of the monitor do not work. kindly solve the problem.
tantong
  • 138 Answers
SOURCE: Pop up menu won't go away.
If you can do the factory reset in the pop up menu, try it. You might have to try with another power supply, cord, or computer and check where the problem is.
Posted on Mar 16, 2008
Benimur
  • 6966 Answers
SOURCE: MONITOR DISPLAY
This will be the nth time you posted the same problem. On your earlier postings and Ask Mes, you were already provided with three (3) probable solutions:
  • cleaning;
  • placing a paper insulator;
  • checking the logic controller (D/A) converter.
And you have done the cleaning only! As likewise noted, HCL would appear to be a limited and regional/domestic model, since you are in the same region, you would be more in a favorable position to secure detailed technical information as to how to resolve the issue.
Perhaps the best approach would be to seek additional technical information within your region, follow the outline/suggested procedures and report to results/status of each.
Incidentally, I am not sure how it is in your country, but I believe it is customary to at least say Thank you especially when asking the same thing over and over again with each time being attended to. So Thank you for using FixYa and good luck with your concerns.
Posted on Nov 18, 2008
kingpin27
  • 13 Answers
SOURCE: out of frequency range set low resolution or refer monitor manual
TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
Posted on Feb 06, 2009
  • 732 Answers
SOURCE: brightness/contrast pop up,options toggling randomly can't select
sugars_30, You or electronics technician will need to (most likely) fix the units "switch-mode-power-supply" !!! Do some extensive reading in my fixya profile and follow the links to other "cold-cathode-fluorescent-lamp" back-lit lcd monitor tech's here on fixya. They and I already have written tons of stuff that will help you to understand the problem you have. When "strange stuff" starts happening with a ccfl lcd display, the first place to look is at the innerds of the monitor. Just do some reading!!! 12fixlouie
Posted on Apr 16, 2010
SOURCE: My compaq 7540 monitor settings menu automatically opens frequent
about the settings menu it is the problem of the main system ic in the monitor.And about the colour on the right side corner pls change the ptc in the monitor .
Posted on May 16, 2010
My campaq desktop monitor 7540 is flickering horizontal direction
Try a different CRT monitor on your computer.
Try your CRT monitor on a different computer.
See if the problem "moves" to the other computer,
or whether your computer has problems with *ANY* monitor.
Dec 27, 2013 | HP COMPAQ 7540 CRT Monitor
COMPAQ 7540 CRT Monitor servicemode pls provide me. Thanks.
You could try this link, but it would be far cheaper to upgrade to a new or second user LED/LCD monitor
http://www.eserviceinfo.com/index.php?what=search2&searchstring=schematics+diagrams+hp+7540+crt+monitor
Sep 03, 2013 | HP COMPAQ 7540 CRT Monitor
HP 7540 crt monitor shrinks to a horizontal line
It would be more economical to purchase a new or used LED/LCD display rather than wasting money on an old CRT monitor.
Feb 22, 2012 | HP COMPAQ 7540 CRT Monitor
MY COMPAQ 7540 17" MONITOR OPEN MENU AUTOMATICALLY
The buttons in front of your monitor is a toggle switch. This kind of switch is that when ' they get older they produces resistance and works with their own way, without pressing them. if you can do open your monitor you can do replace it.
1. prepare the following:
* screw driver/soldering iron/soldering lead/paint brush to remove melted leads.
2. remove all the toggle switch, replace all of it if possible, don't worry its really not expensive, it just cost about 12-15 pesos each.
3. then put in the new switches and try to put in the way it was before.
4. close back the monitor. this is 99.95% sure.
note: before doing these, unplug the wire from the outlet to avoid electric shock.
Jul 12, 2011 | Compaq CV 7500 17" CRT Monitor
My hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.
<div style="FONT-SIZE: 14px; PADDING-TOP: 10px" itxtvisited="1"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblProblem" itxtvisited="1">my hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.</span> </div><!-- answer --><!-- from fixya rte -->
May 12, 2010 | HP S7540 17" CRT Monitor
My volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Sep 02, 2009 | HP w2207 Monitor
HP Pavilion F1523 15" LCD Monitor Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
