Kyocera Mita KM-2050 Printer
Problem for Kyocera Mita KM-2050 Printer
Kyosera mita 2020 error code c-4000
By mianjee on Mar 02, 2009
i am facing problem with kyocera mita 2020 .it is showing code c-4000 .any help
Comments:
May 09, 2009
- yes it was help ful
Same Problem
May 19, 2009
-   I have a problem km-2020 .C-4000.i read servise manual but i dont understand what is polygon motor?waht can i do?-   joshkun
Apr 01, 2009
-   Kyocera Mita 4530 Code C 4000 the same problem...-   Guest
Best Solution
posted on Mar 03, 2009
Helpful)
The Experts
Rank: Wiz  Computer Hardware  Expert
Rating: 81%, 233 votes
Hi am kyocera certified Tech and here is your problem and the solution, hope everything will be fine:
c4000
The Problem:
Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the LSU.
3-Defective engine PCB
Replace the engine PCB and check for correct operation.
This wat the service manual say about this error code but as Tech i recommand for you to do this steps before changing any part and this 60% could fix your problem.
First of all open the back of your machine and make sure there is no cable connector is lose, specially those cables that connected to motors, unplug those cables and plug them again, also make sure that the paper fader cable is connected well. after this put the machine on and off and do this steps:
In the operation panel hit 1087 twice, and this will take you to maintenance mode , then select 906 and hit start, look for the words in the screen, hightlight it and hit start again, the machine may be will tell you put the main power off and on, do this and you will be ok.
Let me know wat happen so i can help you more, if it works donot forgot to rate me
Best Regards
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Kyocera Mita KM-2050 Printer
Questions and Unsolved Problems for Kyocera Mita KM-2050 Printer
Do you recommend Kyocera Mita KM-2050 Printer?
Answer
Answer
how do you get the company name to print out on the fax header
Answer
instead of just hanging up the engage tone drags on for about 4 minutes before it hangs up, how do I... (More)
Answer
Ofter long delay only blank paper printing with code @ PJL SET TIMEOUT = 300, need your urgent... (More)
Answer
printer is connected to mac but will not print
Answer
I want service manual for KM-2050, KM-4050
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
