Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Wont print and it has gone a different language
    President:
  • 2,692 Answers
Find your model, then downlaod the manual for instructions:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
Posted on Mar 07, 2009
I have hp laser jet 1020 printer., when i provide print command all commands are showing in different language which i can"t understand
Called "Junk Print"...Check USB cable, Check USB port dry solder mounted on printer mother board., remove & re-fix farmatter board.. If not solved replace formatter board. If ur technically sound replace USB port mounted on board..
See the image farmatter P/No: CB409-60001
Feb 27, 2015 | HP LaserJet 1020 Printer
Change language on bizhub printing preferences
Remove the Drivers and Installed the driver with English Language.Different languages drivers are available on Drivers CD-ROM and also over the internet.
Jul 10, 2014 | Konica Minolta bizhub C250 All-In-One...
HOW I CHANGE THE LANGUAGE OF THE SWINTEC 7000 TYPEWRITER
To print in a different language, your best option is to get a printwheel that contains your preferred languages special characters. You can see a list of them here:
Swintec Printwheels
May 16, 2014 | Swintec Office Equipment & Supplies
When i type a letter, a different character appears. Example: hello, it gives me heip
You need to get your keypad checked or repaired.It has gone out of order due some physical damage or water entering the body.Get help immediately to prevent permanent damage.
Mar 24, 2011 | Nokia E71 Smartphone
Why would a printer which has been commanded to print in English produce copies in a different language?
This is a driver problem
I suspect a driver for another Language have been installed. Please uninstall and install a driver for the desired language
Sep 08, 2010 | Konica Minolta bizhub C250 All-In-One...
Language change
You can change the language by using the control panel on the top. Go to Settings/Device Settings/ Language.
Apr 19, 2009 | Canon PIXMA MP960 All-In-One InkJet...
Brother HL-1440 Printing Preferences Language Problem
I had the same problem. I finally totally uninstalled the printer from my computer, downloaded the "new" software from the Brother site, and reinstalled it. This is what finally worked for me (WinXPProf.).
Jan 05, 2009 | Brother HL 1440 Laser Printer
Printing Preference in a different language
The driver set you have is defaulted to prob Chinese, especially if you have purchased it on line. You can go to the Minolta web page for your country or region and download an english version that is compatable to your language.
Gremlin11
Please rate my solution, Thankyou
Dec 13, 2008 | Konica Minolta magicolor 2300DL Laser...
Epson Stylus CX3900
I had a problem with my Epson CX5500 Printer when I first installed it, as it seemed to be in chinese language which unfortunately I do not speak :). After not being able to change the language options in the printer options or finding anything in the online manual I went to http://tech.epson.co.nz/downloads/ and updated the drivers and it seemed to correct the problem. As I'm from NZ, you will want to choose a different location on this screen http://www.epson.com/index_g3.html?iref=gblhptst3 but it should make much difference. I hope this helps in some way.
Jul 03, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
LANGUAGE PROBLEM
The print properties are completely software based and have nothing to do with the printer itself. You've had to have installed the wrong version of the print driver or your operating system is set to the wrong default language. I'm assuming you would know if you were running a foreign copy of Windows so I would uninstall the printer and then download and reinstall the English version from the Ricoh website.
Jun 10, 2008 | Ricoh Aficio CL3500N Laser Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
