Question about Jenn-Air JED8230 Electric Cooktop
3 wire cook top to a 4 wire outlet
We just bought a frigedaire 3 wire cook top and our out let has 4 wires. How do we connect them?
cook top: Outlet:
red red
green black
black bare
white
    Novelist:
  • 172 Answers
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Posted on Mar 02, 2009
What does hard wire mean
Hard wiring means NOT a plug in, but rather wires are connected by an electrician, twisted together with wire nuts.
Jan 28, 2012 | GE Cooktops
Power requirement
If you are running new wire to the cook top. You need to run 10x4 wire. The 12x4 wire is not large enough for the 220v. Also the 20 amp breaker is not large enough to run the cook top. You need to use a duel 30 amp breaker.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 09, 2010 | Jenn-Air JEC6288AAB Electric Cooktop
I need the wiring diagram and plug/receptacle specs for kenmore electric cooktp 42732
I believe that if you look on the name plate for the unit , it says that you will need a 30 amp, 220 volt supply circuit . This would be a two pole , 30 amp breaker , a run of # 10-3 cable with ground, and a junction box at the stove top location to make the splices. If you are going to use a plug connection, then a 30 amp 4 wire dryer outlet will give you the connection you need .
Apr 07, 2010 | Kenmore 30 in.42731 / 42739 / 42734 /...
I have a four wire on a 20 Amp service. I need 110 outlet.
4 wire recepticals are used for 220 Volt appliances, there should be 2 hot (117V to ground) and one each Grounding and grounded (read neutral) conductors) Breaker or disconnect should be 2 pole for 220 Volt circuit. A 20 Amp 110/117 Volt circuit would have a single pole breaker or disconnect, one "hot" conductor(should be black or colored , not green or white), one neutral conductor (should be white or neutral with white stripe) and an equipment grounding conductor (should be green or bare copper). It sounds to me like your receptical was wired for 220 V using whatever colored wires were handy. Back up to breaker or fuse (disconnect), and shut off circuit. New 117 Volt outlet will be wired with Black to Brass colored screw (short slot on face), One White wire will be used for Neutral conductor (make sure you know which one it is at the breaker panel) and one of the other white wires may (but shouldent be) used for ground (use green marker to identify it at each end),The third white wire should be removed if you can, otherwise cap with wire nut at each end and coil up in back of boxes. At the breaker/ fuse panel, the Black wire is connected to the breaker (It will be your "hot" lead), The white being used for the Neutral is connected to the neutral buss bar with the other Neutrals, and the green goes to the grounding buss bar (should have other green or bare copper wires. Once all is properly connected and secured but without the disposal plugged in, turn on the power and check for leaking smoke (smoke here is a bad thing) The fuse or breaker should protect your wires and help keep that smoke inside the boxes. Check voltages at the new plug, 117 V accross Short and longer slot, 117 from short to ground (round) and 0 or close to it from long (Neutral) to ground. If voltages check, plug in the new appliance and test.
If in doubt about what you have, dont hesitate to contact an electrician, they get paid for their knowledge and experiance and their ability to keep that nasty smoke inside the boxes.
Good Luck.,
Aug 14, 2009 | Jenn-Air JED8230 Electric Cooktop
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
Jul 02, 2008 | Jenn-Air JED8230 Electric Cooktop
COOK TOP WIRING
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
1,435 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
