Question about Maytag Atlantis MDE6400AY Electric Dryer
Dryer is overheating,I have put a new switch on,and the scean is clean.it is a maytag model mdet336ayw
    Novelist:
    Scholar:
  • 95 Answers
I am not certain which switch you replaced, but most switches will not correct overheating.
In short - You have exhaust blockage or a sensor that is not sensing correctly.
Have you checked the exhaust? the entire hose. That is pretty easy to check.
The more difficult part is to check and then you need to open the case up and look in the area past the screen in all the chambers that lead to the output of the dryer.
Next if that does not fix it, to save a service call replace the one or two temp sensors that are in the exhaust chamber channel after the lint screen. You will have to disassemble the front and maybe the back of the dryer. The front will probably have access to the sensors.
The sensors look like black oval shaped plastic with a little small bullet-type item on the end of the black piece facing in the channel chamber. They are around $15-25 each.
Get back to me if any one of those do not work.
E
Posted on Mar 02, 2009
My Maytag Neptune dryer doesn't turn on
I would look for air restrictions that may cause overheating. I would clean the dryer up and hunt for the duct fuses. Some models have 2. To get into the dryer and more Click HERE
Sep 02, 2011 | Maytag Dryers
I Have a MDET336AYW Maytag electric dryer. It tumbles and gets hot but makes an awful screech like a bearing or something it going out of it. Can you help me get it a part and find the problem?
Part 2 and 3 on this diagram are the glides and felt pad which are used to support the front of the drum and when worn out you will have metal to metal rubbing.
Part 17 is the drum support roller for the rear of the drum. You have two of them.
You'll have to determine where the noise is coming from to know which is the problem. Using the diagram for the cabinet you can remove the front to access other parts. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174209&diagram_id=1362912#d1362912
Jul 28, 2010 | Maytag Dryers
Maytag dryer overheating
have u replace heating sensor
Oct 22, 2009 | Maytag PYE2200 Dryer
Dryer,timer switch won'tmove & cool air only.
Begin by replacing the times. Then you will most likely find that you are back in business.
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer won't start
check your circuit breakers for dryer they may have tripped whenlights went out. write back if not the problem let us know a little more about problem
Jan 30, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
My maytag dryer MDET336AYW won't come on
probably have a back door switch. look and see if when you close the door it closes the switch
Jan 04, 2009 | Dryers
Maytag electric dryer over heats
I removed the front by getting the screws out from inside that hold the front on. I unhooked the lid switch and got the front out of the way. Guess what I found? A big ball of lint right in front of the blower. The whole filter housing was full of lint!. To make matters worse the blower was loose!. So I used my super duty shop vac to clean it up and I replaced the fuse(mounted next to heat element)yes it was blown because of the lint ball. 3e11794.jpg
Dec 18, 2008 | Maytag PYE2300AY Electric Dryer
Maytag dryer
The thermal fuse is blown its mounted on the heater with the two smaller white wires. Check the vent for restrictions (since overheating is what caused it to fail) Was the dryer taking long time to dry before it stopped?? If so there is a definate vent restriction. Part number LA-1053 comes with new high temp thermostat too (recommended).
Oct 16, 2007 | Maytag PYE2300AY Electric Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
125 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
