Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Workcentre c2424 System error 07,007.40:452 problem. please wait???
    President:
  • 2,072 Answers
That has to do with the process drive motor assembly. The gears may have jumped, It is located on the right side of the machine toward the front, A motor assembly , with several white gears. There are 2 holes you have to use paper clips to align the gears and an arrow on the bottom to align.
The maintenance kit plate may be binding also. That is what the maintenance lit sits on and pivots up and down. Black plastic.
Posted on Mar 02, 2009
System error # 07,010.43:27456 on a xerox c2424 copier
The printhead is stuck in the tilt position, need to replace the process motor camshaft kit, part number WCC2424-Z2
http://www.iteminconline.com/wcc2424-z2_wcc2424-z2-xerox-workcentre-c2424-process-motor-camshaft-kit.htm
Jul 07, 2015 | Xerox Office Equipment & Supplies
System error 09,005.40:143310 Xerox workcentre c2424
You either have jammed ink sticks or a bad Ink Loader 200-4711-80
It is fairly easy to replace, if you can get the covers and Document feeder off.
Whit
Item, Inc.
May 06, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcentre c2424 error code
One of two things most likely.
1. The wiper blade is stuck to the print head,or 2, The print head blosk has a lot of spill over ink built up in it.
That code is caused by the inability of the print head to move properly. Either left to right or pivot front to back to get into the print position.
You have to remove the covers to access the stainless steel print block. It is located about 2/3 of the way back on the lower left side of the frame. It is a one inch by one inch square block that may have a lot of buildup of spill over ink in it. If the wiper is stuck you have to remove the ink loader , where you add the ink sticks , to access the area between the print head and drum, It is a pink blade the is between the drum and print head, it wold be stuck to the print head not allowing it to move. Just carefully unstick it from the print head
Mar 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Oct 22, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
System error
7,0XX.6x Errors - Program Faults
a.
Reset NVRAM and retest.
Jul 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
C2424 System Error 07,010.43
You have an E-mail address, I can send you the info.
May 15, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Error message
gearbox error refering to the printing tilting. probably have to have a service call
Dec 12, 2007 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
137 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
