Video Game Consoles & Games Logo
Posted on Mar 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
To play playstation cd on pc i need a s/w interface
Anonymous
Level 2:
Sniper:
  • Expert 55 Answers
  • Posted on Mar 02, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
55
Questions
0
Helped
39420
Points
175
Your can download the Playstation emulator from here. http://www.epsxe.com/ . Hope you find it useful
HU8643773
Here is what I have for that model of PS2.
The 128-Bit Emotion Engine is the first chip of its kind. No other mass-market computer technology on the market comes close to its power. In the PlayStation2, this chip is used as the workhorse of the console. It processes all physics and math calculations.
The PlayStation2 has a 128-Bit Emotion Engine. The 128-Bit part of the title means that this chipset both processes information and sends it over a 128-Bit bus (A Bus is the pathway between chips on a circuit board. A wide bus carries more bits of information and is thus faster than a narrower bus).
You may think that your PC has a faster processor, but remember that the Emotion Engine has inherently faster 128-Bit processing and it is just a part of the overall PlayStation2 power.
A small note for the really detail oriented: The reason that the speed is 294.912 MHz, is that it must be a multiple of a required processor speed that supports the DVD ROM operations.
* Dimensions: 301mm (W) x 178mm (H) x 78mm (D), (12" x 7" x 3").
* Weight: 2.1 kg (4 lbs. 10 oz.).
* Media: PlayStation2 CD-ROM, DVD-ROM, and PlayStation CD-ROM, CD Audio
This means your PlayStation 2 will basically play all your old PlayStation games (but not make them look any better), all music CDs and all North American DVDs.
* Interfaces: Controller Port (2)
These are the same as the controller ports on the current PlayStation.
* Interfaces: Memory Card Slot (2)
These slots are very similar to the ones on the original PlayStation, except they support the new, faster transfer rate.
* Interfaces: AV Multi Cable Output (1)
This is where you plug the cord that goes to the back of your television.
* Interfaces: Optical Digital Output (1)
This port will let you send data directly to a digital receiver. This is perfect if you plan to plug your PlayStation into a DTS or Dolby receiver and get perfect sound.
If you don't use digital output, your data will be converted to an analog signal and then be converted back to digital at the receiver.
* Interfaces: USB Port (2)
USB enables you to connect any number of devices to your system with a high-speed data link.
* Interfaces: I.Link (IEEE1394) (1)
The IEEE139 port is known by two names: I.Link and for Mac owners, FireWire - there are some minor differences between the two. This high-data transfer port has the advantage of supplying (some) power to devices that are connected. You can expect that an enormous number of hardware devices will use this port including speakers, printers, and other like devices.
* Interfaces: Type III PCMCIA Card Slot.
This slot is a lot like a laptop's add-in slot. Here you will be able to plug in a modem and eventually the connection for Sony's planned broadband network and hard drive.
Pes 2013 for play station 2 won,t start
The game is for the PS3, not the PS2, which means it won't play on an older system.
My ps3 is set to 1080i but when i play need for speed undercover it plays in 480p
Open the PS3 - selected - the display Settings - video output Settings - choose TV interface for Hdmi - automatically
If this is not good, he connected HDMI line, and then hold down the PS3 power key 5 seconds. The PS3 will reset the display Settings. Select the default best resolution oh •
If you want to have better ps3 controller, here are cheap ps3 controllers
Can I download pictures from my digital camera onto my Dell Latitude d410? If so, how?
You can download from any digital camara.Load the CD that came with the camara or obtain one if you can. You need the interface cable that is purchased seperately. You do not specify the camara spec so you will need to Google the" model and pc interface cable". If you have the cable then the next step is the camara driver which should be on your cd that came with the camara. Plug in the cable to the camara and to the USB port on the PC (make certain the camara is set to the Play position or PC). Windows will ask for the driver location. Insert the cd and continue. If windows does not see the driver you will need to locate it manualy from the cd or on line and download it to your desktop from the manufacturers web site. All camara companies have a support website for the drivers. Once the drivers are loaded then you need to switch the camara to the Play position so it can be seen by the computer. Go to the control panel in windows and select system then hardware then devices. If all went well you should see the camara listed as a device. Now you need the camara software or a picture viewer from the web. Here is the web kocation http://en.kioskea.net/telecharger/telecharger-653-picture-viewer
If all went properly 1. driver 2. picture software then you should be all set to handle your pictures. Good Luck Phil [email protected]
The cd that i have will it play on windows xp?
you can play ps cd to your pc, but you need to have an emulator for PSX in your computer. you can visit http://www.emulator-zone.com/doc.php/psx/ for the emulator. check also the forums in the website for additional information.
1helpful
USA SPEC PA11-Vol unit will not play iPod using the iPod cable.
where did you plug this behind the radio ? or at the cd changer cable ?, the interface needs to be plug into the radio not the cd changer cable
My playstation 1 wont play games and just say please insert cd rom? It plays music but not games...Do I need a ps1 cd rom? is there one?
it sounds like your laser is either dirty or it needs replaced. when a laser starts to go they usually will play music but not any games or movies.
3helpful
3answers
How to play play station-2 in pc
you will need an emulator for this. its easily found online on many websites. just install the emulator on your PC and go for it:)
Playstation 2 problem
you need to clean you the lens by using the cd lens cleaner. you just play this cd lens cleaner as if you are playing a music then until a message of completion
2answers
Need help!!!!!!!!!!!
A previously released Madden NFL 08 update for the PLAYSTATION 3 was causing an error code (80010009) to appear and prevent online game play.
There has been a fix published by Electronic Arts (EA) on this problem.
This has now been resolved, but if you already downloaded the update, you will need to remove it before the game will work.
Please follow the steps provided by Electronic Arts below.
If you have encountered an '80010009' error message after downloading the most recent Madden NFL 08 update, please perform the following steps listed below:
  1. Press the PS button on the controller and select QUIT.
  2. In the main screen of the XMBTM user interface, select Game.
  3. Highlight the Game Data Utility folder and press the X button.
  4. Highlight the Madden NFL 08 file and press the Triangle button.
  5. Delete the file.
  6. Restart the game.
This will allow you to launch and play Madden NFL 08.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
