Question about Canon PowerShot A50 Digital Camera
My camera not working and not displaying any thing. not blinking any led
    Novelist:
  • 98 Answers
Try the following:
1). Check batteries whether they are fully charged.
2). Check with Battery terminal are clean. You can clean them with a ear bud using some alcohol or spirit. Wipe the battery terminal with a clean dry cloth.
3). confirm that the memory car slot/battery cover is securly closed.
4). Reload the battery several times. This will also remove poor contact between camera and battery terminals.
5).Check battery are loaded in the correct direction.
If the probelm persist, you might need to take it to the service center.
Posted on Mar 02, 2009
Ok button don't work on magic remote
1.Put your phone on camera mode, then press any button of remote with the LED of remote facing the camera. if the remote works you will see the blinking REMOTE LED in your phone while on camera mode. IF THE REMOTE DOES NOT WORK, THEN NO BLINKING SHALL BE NOTICED. If the remote works, then check the receiving point at the unit.
2. If no blinking on cellphone while on camera mode, open the remote and check signs for broken tracks or electronic components on board. Also accumulated dirt can inhibit buttons from making good contact when pressing. Clean with fine cloth if there is dirt.
May 04, 2014 | Televison & Video
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
Does not turn any equipment on or off. has power but does not communicate at all. I have rebooted, etc. but no luck. Old remotes still work. It appears that IR is dead.
If you have confirmed that the remote's IR emitters have failed and you are out of the warranty period (1 yr), you have a few choices. You can contact Logitech. They will usually issue a 50% discount on a new remote. Or, you can try to repair the remote yourself using the guidance in this article: http://hubpages.com/hub/HowToFixaLogitechHarmony880Remote
Or, you can have it repaired for $14 (or less if you haggle) from this Ebay seller: http://cgi.ebay.com/We-can-Repair-your-Harmony-880-Remote_W0QQitemZ200437939363QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2eab083ca3
Jan 16, 2010 | Logitech Harmony 880 LCD Remote Control
Led with number 9 displayed is flashing
LED 9 flashing can mean many things. Here is the list of "flashing codes" for the vostro 1510.
Keep in mind a flashing led is going to blink 3 times. for example,
number one would look like this:
On (solid lit). Blink, blink,blink (paused off) blink, blink, blink... (paused off), (then repeat)
1. ON-FLASH-FLASH = No Ram or ram not seen
2. ON-FLASH-ON = Ram has a problem
3. FLASH-FLASH-FLASH = Motherboard failure (replace board)
4. FLASH-ON-ON = CPU Fault/failure
5. FLASH-ON-FLASH = LCD detect failure/fault
6. ON-ON-FLASH = MINI pci card (controller) failure/fault
7. FLASH-FLASH-OFF = Keyboard fault/failure
8. FLASH-OFF-FLASH = USB FAILURE
9. FLASH-FLASH-ON = Video BIOS or BIOS issue
10. ON-FLASH-FLASH = Modem issue
Depending on the blinking code, you might just need to re-seat or replace your RAM or your CPU. But then again, you could have a more severe motherboard issue.
Nov 01, 2009 | Dell Vostro 1510 Motherboard System Board...
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Wont turn on, LED just blinking
Couldent find any help, pushed the small switch until display reacted then touched the touch fields one by one in order from top left until the display showed nine. Then beep it all worked again !
Gggenau offered a rep at 400-500 eur for this ! Shame on them !
S:DOlberg
Jan 15, 2009 | Gaggenau 28 in. CK 171 Electric Cooktop
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Kodak easyshare C875
Are you using Lithium batteries?
ALL Kodak cameras have huge problems with alkaline batteries, even brand new ones.
Hope this helps.
Jan 02, 2008 | Kodak EasyShare C875 Digital Camera
All three LED's blinking, no video
hi, does the three lights blink only after u connect it to a display card??if yes then check if any of the connecter pins are damaged, or check out the display card..bye let me know
Dec 08, 2007 | Dell E173FP 17" LCD Monitor
Two green LEDs are blinking?
The two green LEDs on the back of the camera indicate a number of camera conditions. If they are both blinking, the camera's memory is full and the camera will not take any more pictures.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Canon PowerShot A50 Digital Camera Logo
52 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
