Question about Acer Aspire 5610-4648 Notebook
No. im on linux with the acer aspire one. i dont want to change to windows, so is there a solution for the mic involving staying on linux? appreciate the help. email me carl.guevarra@gmail.com thankss
  • Anonymous Mar 03, 2009
    thank you but i still want to know how to use it with everything else, even with simple things like the recording videos.
    appreciate it. let me know asap
    President:
  • 1,223 Answers
Pls try to search this forum u will find the solution soon
https://help.ubuntu.com/community/AspireOne
the latest is the internal mic will only work for Skype and the Internet Messaging applications installed on the unit
Posted on Mar 02, 2009
Hello fixya. I just reinstalled windows 7 for my acer aspire 5943G but for some reason i cant get the mic in the computer nor the mic in my headset to work, i dont know if its because i need a driver,...
Check the device manager to see if a microphone is installed. If it is, it may not be installed correctly due to a missing driver or wrong driver. If you find a mic installed, right click and get the properties. Find the tab that says Update driver and allow the laptop to connect to the internet to find the right driver. If no microphone is detected, you can manually install the microphone through the Control Panel under Devices/ Add Hardware. From there, you will select microphone and be given the option to either install it with a disk or by selecting the manufacturer/model.
Jul 20, 2011 | Acer Aspire One PC Notebook
I will ask if i can download windows 7 on linux acer aspire 4738?there will be a problem?
there won't be any problem as far as Windows and Linux, but this is a fairly involved procedure.You'll first need to create a Windows partition on your hard disk in NTFS file system format. Otherwise,Windows might overwrite / erase your linux installation when Windows 7 installs.
make the windows partition the "Primary" or "Boot" partition.
When Windows 7 installs, it may ask if you want to delete the linux partition.Answer "NO" to this.
The next concern is which operating system will boot by default,Windows or Linux.
I had no problem doing this with Windows Vista, and whe Vista booted,it listed a choice of operating systems to boot,and I would select either Windows Vista or Ubuntu Linux.
Apr 03, 2011 | Acer Computers & Internet
How do i reset the password when i dont know the original pw?
A password is required to install anything on Linux, in order to prevent any malware or unauthorized users from doing harm. In order to install the program you wish, you will need to enter your password, which is the password you used to log in to Linux. I am assuming your account has sufficient privileges. If you set up an administrator, root, or su (superuser) password when you first booted up Linux, enter that password.
Mar 27, 2010 | Acer Aspire One PC Notebook
EasyPeasy installation using USB
dont bother with linux nothing works on it and it messes up lots stay using windows
Jul 21, 2009 | Acer Aspire One AOA110-1588 Notebook
Hi.. im having problems with my acer aspire one netbook. i wanted to refpormat the linux linpus lite OS so i can start new. can you help me with that? thanks
no problem if you want ot repormat the linux then change win xp sp2, or vista its up to you if what operating system you want install it...
somtime some laptop the driver is vista supported only if you put xp you to donwload the xp driver..
Jun 05, 2009 | Acer Aspire One A110-1831 Notebook
Windows on the acer aspire one 110-AB
I do not believe this ...the only way is if there is a dual boot system installed so when you boot it should prompt you to choose the op sys ya want to run ...the solution is as fallows...either you install the windows xp ...but I heard about problems with some notebooks that came with Linux cause the HDD is too small to support windows,,,( ex 2G...) and if you install it you will not have room for anything else ..if you dont want to mess with this my solution is .. web msn messenger ..so you will be able to use it without install it ...
https://login.live.com/login.srf?lc=1033&id=45940&ru=http://webmessenger.msn.com/default.aspx?pop=true&tw=20&fs=1&kv=9&ct=1239080877&ems=1&kpp=3&ver=2.1.6000.1&rn=ZhIEL9kQ&tpf=372872e4f545ca86ae55c572225f3703
make sure you disable the pop up blocker for this site ....Good luck !
Apr 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
How to work with an acer aspire mini laptop with linux?
2 - it does not have a cd ! This is not a linux or windows thing ! U can use a usb cdrom if u realy want to...
3 - u;ll need a usb stick bootable with dos OS on it and the kit for xp ... there is plenty of info on google... But i recomand useing the linux(faster, more stable ... prettyer :) )!
Jan 07, 2009 | Acer Aspire One Netbook 8.9" Notebook
Can not down load msn
If you have linux on your aspire 1 then you can't use the original messenger because it is made for windows systems. you can try using it with Wine or find a linux messenger replacement.
for example Pidgin works with MSN accounts and it has a linux version.
http://www.pidgin.im/
IM all your friends in one place Pidgin is an easy to use and free chat client used by millions. Connect to AIM, MSN, Yahoo, and more chat networks all at once."
Jan 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
Itunes
click on this link:
http://www.apple.com/downloads/
then click download :)
Aug 27, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5610-4648 Notebook Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
