Question about Technics Audio Players & Recorders
I have a Technics ST-X33 am/fm stereo tuner and I don't know how to pre set the buttons so that I can set the radio stations to specific buttons...can u help please
4 Suggested Answers
xalint1
  • 152 Answers
SOURCE: Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Posted on Jul 30, 2008
  • 57 Answers
SOURCE: Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Posted on Jul 06, 2009
Grubhead
  • 5309 Answers
SOURCE: memory part of a Technics tuner does'nt work
Identify the main area on the pc board, and look around for a odd shaped Electrolytic capacitor. It might even have odd printed board number IE: mc500, not c500, for example.
If you find one it could be a Memory Retention Capacitor. They often have a low value 0.22uf and low voltage 5.6 for instance. It could have failed and so not supply the chip that stores the information, with power when switched off.
I can't say it will have one, but it's worth a try. They are in the Maplin catalogue for under £5!
Posted on Nov 18, 2009
How do I programme my Technics ST-Z400l Tuner please?
CUSTOMER CARE PHONE NUMBER IS: 1-800-211-7262 PRESS 0 AT EACH PROMPT, IGNORING MESSAGES. LET ME IS YOU NEED MORE HELP.
Nov 13, 2014 | Technics Audio Players & Recorders
Technics ST-S3
1. Select the lowest FM frequency you want manually. You should hear it.
2. Press MEMORY followed by preset one.
3. Repeat the process for the remaining frequencies and buttons.
If you don't hear anything when you tune manually, the frequencies are not being received with enough strength. There could be an antenna problem.
Dec 28, 2013 | Audio Players & Recorders
Am antenna technics st-z550
Loop antenna is directional.
But you can extend the wires so as to find a good spot.
Jul 29, 2012 | Panasonic Technics St-z550 Quartz...
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
I am looking for the manuals for Technics SE-A808 Stereo Power Amplifier ST-K808 Quartz Synthesizer Stereo FM/AM Tuner/Preamp SH-R808 Infrared Wireless Remote Unit Kind Regards John
I don't believe that these are available electronically without cost. If you can describe the problem you are trying to solve, I may be able to guide you through the repair.
Dan
May 25, 2011 | Audio Players & Recorders
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
Do not have manual. Need to program tuner channels and clock.
For clock turn key on and stereo off. Press and hold the function button for 3-5 seconds. the clock should appear with the hours flashing. Use the up-down buttons to set hours. Push the right button to set the minutes. Now turn on the stereo with the source (or power) button and your done!
Remember key on stereo off. hold function, the rest will become second nature once you've done it a few times.
Tuner pre-sets are super easy. Tune to the station you want and then just hold the # button (1-6) that you want that station on for about 3 seconds. The channel your on, (e.i 104.9) will flash a couple of times and then stop flashing. When it stops flashing it's in the memory. Tune your next channel and hold # 2,3,4,5,6, If 6 isn't enough push BAND and your on FM-2 with 6 more pre-sets, Push it again for FM-3 with 6 more presets. Push it a 3rd time for the AM band with 6 pre-sets and one more time to get back to FM-1.
Apr 07, 2010 | Pioneer DEH-P3100 CD Player
How to program pre-sets on a Sony tuner ST-S100L
Tune in the correct station with the big +/- buttons. Then press "memory" then type in a number with the pad (it will do double digits, but normally a single digit is preferable) then press "enter"
Now typing in that number then pressing enter will take you to that station.
Good luck.
Dec 12, 2008 | Sony ST-SA50ES 2 Channels Tuner
114 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
