Question about Sony VAIO PCV-RS530G PC Desktop
Low memory on C drive
I've transferred all high memory files (pics etc.) from the C drive to the D drive or my external hard drive. I keep getting low memory dialogs and many things won't download even though I thought I had specified them to go to the D Drive. Can I switch the C and D drives purposes or do I have to buy more memory? It seems like the memory ran out on the C drive pretty quickly.The C drive has 14 gigs and the D has 129. Thanks in advance for your help.
  • 3 Answers
I have same model computer and discovered that, like you, Sony had irresponsibly set up the computer to have two partitions on the 160 GB HD, setting the "C" system drive to only 15 GB, and the unused D drive to the remaining 130 or so GB.
Even if you save all your user data to the "D" drive, you can still run out of space on the 15 GB "C" drive if you have applications that require a lot of that space (MS Office suite, graphics and media apps, etc.)
Truly the setup is an unjustifiable procedure on their part. I called tech support but did not get any encouraging help - beyond them telling me to reformat to a size I preferred...
I ended up saving off all data, then reformatting and repartitioning the hard drive, and reloading the Windows OS and applications and data. Not for the faint of heart.
While there are a few paid tools you can buy that claim to re-size partitions on-the-fly without requiring you to save off and reformat, I have no experience with them. They may be fine... or not...
Mostly I am just incredulous that Sony could have ever thought it a good idea to assign the smallest space to the C drive OS partition.
Posted on Aug 10, 2009
  • 643 Answers
U also need to check your desktop, recycle bin and etc...
Recommend u to run CCleaner to free up hdd space.
http://www.ccleaner.com/
Posted on Mar 02, 2009
  • 4,889 Answers
14GB is not usually enough for a C drive. Because the system restore feature is good at hogging up your space. And yes gettting a new hard drive should do the trick. But make sure that the windows drive is allocated atleast 20-40GB. Maxtor drives are an inexpensive option. I have seen a 1000GB Maxtor drive priced at around 120$!
Sai.
My local disk :c shows red?why?
If you're using Windows 7 or 8 or Vista, that means that a lot of the disk has been used, and the left memory in the disk is low. Can you please provide me with the data of max space on the disk, used space and the remaining space. Thank you!
Jan 16, 2013 | Computers & Internet
How do I transfer pics from my pc back on to my fuji S5700 camera
You'll need to use a card reader. Once the memory card is in a card reader (either built-in to the computer or connected via USB), the card will appear to the computer as another external hard drive, and you can copy files to it the same way you usually copy files.
Be aware that if you've done any editing of the pics (opening a pic in a photo editor and then saving it without doing anything counts as editing), the camera most likely won't display it.
Feb 15, 2012 | Cameras
Can an external memory harddrive can make the speed of my computer faster,if it can what are the specs of hard drive do i get?
The speed of you PC depends on the clock speed of the processor and supported by the Random access Memory - internal memory - that supports the processor which is the CPU- central processing unit.
So unless this is improved it wont make a difference. However keep you PC with low load of programs and clear of any virus and unnecessary files that might bring the speed lower
Jan 24, 2011 | Dynex External USB 2.0 Multiformat Memory...
Menory low on harddrive a220n
If your disk space is low on the Hard Disk drive, delete or move some files off. You can replace the hard disk for 30-50 dollars with a larger one. If it is low on memory (RAM) you can add more up to the system limit from several sources.
Thanks
Jan 06, 2011 | HP Pavilion a220n (DK218A#ABA) PC Desktop
My computer keeps saying low disk space on c how to i fix it so i can u lapot
For Low Disk Problem, you can try these steps:
Dec 21, 2010 | Acer Aspire 5315 Notebook
Low memory, slow speed.
Hi, when you copy files to another location, the original ones will stay there until deleted. so if you are sure and know which files have been copied you can safely delete them, but rember to delet them from the recycle bin.
I hope this has helped you and if you need anymore assistance please ask.
Jan 30, 2010 | Fujitsu AMILO PC Laptops
I`ve just formated usb memory disk and lost all drivers
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 29, 2010 | Kingston Technologies 512MB DataTraveler I...
I can't get my card reader to work on my pc
when plugging into a USB you'll hear one of two sounds
a sound from low to high or a sound from high to low
the low to high sound it that the USB is working fine
the high to low means the USB is not working , on
another note SanDisk uses a utility on everyone of its
cards a troublesome utility that is not easily worked
the older it is the less performance it will have , but ultimately the sound has to be there the sound is the
computer recognizing the plugged in device which you'll find in my computer .
Jan 14, 2010 | SanDisk MobileMate SD Plus 5-in-1 Media...
I believe I have a virus or worm that Norton cannot detect
Ok. How much space do you have free on your hard-drive right now? (I'm assuming that you know how to check this).
If its low, then maybe you didnt free up enough space on the drive. If it is high however, then answer this: is the message you are receiving telling you that you are low on disk space? or is it telling you that it is low on virtual memory space?
if its low on virtual memory, then the problem could be many including 1) virus etc 2) a program is running that is using up more RAM than is avaivable 3) you need more RAM on your system.
if its low disk space, then the problem could be 1) You need to free up more disk space (that may mean getting a bigger hard-drive installed)
Try using an updated virus scanning utility. If it says that you are virus free, then try one of the solutions above.
Oct 02, 2009 | Computers & Internet
The computer still indicates low disk space and has not recognized theMY Book as additional **** space
Does it see your external hard drive at all? If so I hope you have like a 500 gb and transfer all your pics, vids and other data files over to your external to free up space on you computer hard drive.
Jul 01, 2008 | Computers & Internet
Sony VAIO PCV-RS530G PC Desktop Logo
114 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
