A consitant red light with no alarms. doesent seem to effect enginge performance
Have You Heard Your Alarm Sound Recently?
Leave The Kill Switch Lanyard Out And Crank The Engine To Start
Engine Will Not Start And Alarm Should Come On?
Does This Happen? If Yes---
Does The Red Light Have a Small Graphic In It Like a Oil Can Or Thermometer? If Yes----
This Gives You An Idea Of What The Light Is Telling You--
I.E. Oil Can Oil Level In Remote Oil Tank Is Low
SOURCE: Yamaha 50 hp motor oil red and green oil sensor lights are on
we have a red warning on Yamaha 50 hp 4 stroke outboard engine and it runs rough during forward,its ok if there is no load.
we have changed spark plug, engine oil also cleaned carburator .
looking for solutions
SOURCE: i have a 98 yamaha 150 2 stroke outboard engine,
Although water is seen thru the tell tail hole, your engine is overheating. When were the thermostats replaced last? Water pump impeller may also be fatigued, and not pumping enough at high RPM's.
SOURCE: YAMAHA 2001 40 HP NOT PUMPING WATER,PUT OUTBOARD
Hi, it needs to have the water pump overhauled and it is not something you should attempt on your own. Take it to someone experienced to have it done correctly. Regards Phil.
