Question about Logitech X-230 Computer Speakers
Logitech x-230 serial wiring diagram
Hi, i was wondering if anyone has a diagram of the serial plug as i'm putting the sub into my car and i cant work out wat pins are for where.
The pins i need is the power switch and the sub sound input for the input of the sub board.
Thanks Joseph Bailey
3 Suggested Answers
likwidstate
  • 17 Answers
SOURCE: Logitech x-230 speaker system
Ironically enough, I went on here because I have the satellites but no subwoofer! LOL, what are the odds. Anyways, if you happen to receive this information, can you please email me at ben.petrofsky@live.com?
Like I said, I'm searching for the same exact information for a similar problem and this would REALLY help as I can't power the speakers without this.
Posted on Sep 02, 2009
SOURCE: logitech x-230 9 pin problem . i need to manualy
worked on this for 3 days but i finaly got it I had to open it an follow coper lines using datasheet, the connector is RS232 the pins are
1 = LED+
2 = IN R
3 = OUT R
4 = OUT L
5 = GND
6 = ON
7 = 5V
8 = GND
9 = IN L
so you have to put a swiths between pin 6 and 7
you should also put a potentiometer GND-IN-(AUDIO SOURCE)
and a led between pin 1 and GND
and that is it!
---POXTRON---
Posted on Aug 04, 2010
  • 104 Answers
SOURCE: where can i purchase the audio cables that connect the Logitech X 230 sub woofer to my laptop and mp3 player
Usually you can purchase audio cables for speakers and sub-woofers from any or authorized PC outlets.
Just explain to the dealership what you want to connect it to and they will shoe you the right "jack" to buy.
G.
Posted on Nov 01, 2011
Do i have to have the sub-woofer in order for my logitech X-230 speakers to work with my computer?
Certainly any large speaker itself cant be used with
very weak computer out signal
The signal should have power amplification in addition to
voltage amplification to energise large speakers
Oct 09, 2012 | Audio Players & Recorders
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Jan 18, 2012 | Logitech X-230 Computer Speakers
How do i connect my logitech x-230 speakers to my laptop?
Hi, Thanks for using fixya.
On the top close to the screen, side or back of your loptop you should have a speaker port and a mic port plug the speaker wire in the speaker port.
Terry
If you have any further questions regarding this matter feel free to post a comment or if you are satisfied with my answer, please give it a rating for this is the reason I do this work.
Feb 21, 2011 | Logitech X-230 Computer Speakers
Logitech x-230 9 pin problem . i need to manualy insert wires into pin holes.. So can anyone tell me the color and pin hole nunber to put right wire into
1 = LED+
2 = IN R
3 = OUT R
4 = OUT L
5 = GND
6 = ON
7 = 5V
8 = GND
9 = IN L
and that is it!
---POXTRON---
May 15, 2010 | Logitech X-230 Computer Speakers
Wiring assignment for plug of Panasonic SB WA340
my woofer lost the sound I.C how can i solve this problem?
Feb 13, 2010 | Panasonic Audio Players & Recorders
Apr 02, 2009 | Logitech X-230 Computer Speakers
Adding logitech r-20 to pc
Sorry i cant show you the diagram here because there is something wrong with the website so i uploaded on the internet and here is the link.
Aug 07, 2008 | Logitech R-20 Computer Speakers
Service Manual for X-230
I used a Radio Shack D-Sub 9 Pin Connector #276-1427
Pin 1-Empty Pin 2-Purple Pin3-Yellow Pin4-Red Pin5-Shield Wire & Green
Pin6 & Pin7-Gray Pin8-Blue & Black Pin9-Brown
The pin numbers are on the face of the connector and are hard to see.
Feb 17, 2008 | Logitech X-230 Computer Speakers
Convert d9 to rca connection
its not worth it 1st off to run off tv and it need sit corrosver from main unit to understand 1650 hertz lower otherwise be outtta control best bet to buy mtx 12 100 on ebay have a real nice quilty sound dont waste time with that even the way u wnan do it will still sound pooor i run for my buddies these off his tv rca outs to mini jack steri works ok not greatest not for movies for pc even then low line not worth your time to rug it that way just use front green mini sterio jack to a female mini sterio to rca cables from rca out of tv that way u get fronts and sub ok
Oct 10, 2007 | Logitech X-530 Computer Speakers
Logitech X-230 Computer Speakers Logo
1,958 people viewed this question
Top Logitech Audio Players & Recorders Experts
sonic boom...
sonic boom...
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
