Question about Abit Computer-model:AN78GS Motherboard
Mother board freezes on abit logo wile starting....
I checked power supply and its good. I tried putting one ram chip at a time an still... disconnected CD, HD, and still... i just build from scratch. it booted fine for a week. then when i started disconnecting components or switching spots it would freeze on logo so i had to wait about an hour and it would boot fine but after 2 weeks it finally got stuck on the abit logo and i cannot go in to the bios. I also tried reseting bios and taking out the battery.. haaaaaa... help
  • Anonymous Mar 03, 2009
    Ok I checked the power supply with a flashlight and itlooks good. The thing is that at school I also tried booting up with anotherpower supply and it did not work...same problem.. Now I'm not sure about openingthe power supply..(Don’t want to void the warranty on it….) Thanks for thereply… please reply if you got more ideas….
  • 4,889 Answers
Hello Carlos,
Did you open the powersupply and check? I have recently worked on a PC with a similar fault and I found that the circuit board is partly charred and couple of capacitors leaking. I advice that you check it and post back..( I can't forget that repair coz I got one hell of a shock while working on it)
Posted on Mar 02, 2009
Hp Pavilion, Power supply Inactive, HHD savagable, intel Chip Savagable, i was thinking a new motherborad for the chip and the hard drive ????
If your Desktop not start it means not you mother board problem because starting you find your SMPS proper running or not. Because SMPS supply all power in CUP so you check it SMPS on or off position. if SMPS ok then you check it mother board light on or not, if on then ok or not on then you change SMPS supply.
If your display issue then you check it RAM and HDD.
Computer Support
Feb 20, 2014 | HP Pavilion a305w (DM181AR) PC Desktop
I have an abit av8 mother board and am tryng to install a new power supply (G7 powr exteme) the LED2 is flashing with with no constnt power availabe to power up te system please help is my board or th
Hello here is the homepage:
You have probably connected the +12 volt 4 pin, connector wrong.
The pci-e graphic connector, sometimes fit here.
When this happends the mainboard will not boot up.
Try to read the manual for the power supply.
Good luck
Nov 09, 2012 | Abit Computers & Internet
The mobo continuously beeps (ram not properly placed). so i took out the ram, reinstalled it and it worked. recently i wanted to change rams, so when i installed the new rams the mobo beeped again (similar...
I am not sure if you have tried this, but take one stick of ram put it in the first slot. Try to boot if it beeps or not, power down and move to the next slot with the same chip (we are assuming this is a good ram chip). Repeat for every slot on the computer. If you have 1 or 2 slots that beep and the rest do not; bad slot on the mother board. If all slots beep, try a different chip (bad ram??). If no slots beep, repeat steps with each individual ram chip (you could have just one or two bad and causing all the issues).
Hope this helps
Mar 26, 2012 | Abit NF-M2S Motherboard
Toshiba tab turns on but Screen stays black what do I do
I would check the ram chips first,, pull them out and reinstall them, most of the time this will work. if not.... try starting the laptop with only one ram chip installed, then try the same thing with the 2nd ram chip install,, test one at a time..
If this dont work it may be a bad GPU connectoin to the mother board,
This can be fixed but in most cases a new mother board is needed.
Jan 11, 2012 | Toshiba Computers & Internet
No power,power supply seems ok,green light on mother board on. when pluged in the fan runs for a couple seconds and turns off.power button has no effect.
sounds like a mother board issue,
start with pulling out all ram chips and re try,,
then try pulling all cards out like old modem and also cdroms.
if ever thing but power is unpluged its a bad mother board or CPU chip
Mar 12, 2010 | E-Machines T3958 (827103050974) PC Desktop
Problem on Boot
Hello tccat1,
Definitley sounds like a bad motherboard, however, try removing the memory and using a different stick if you have some. Maybe 512 see if you can at least get it to post.
Nov 14, 2008 | MSI K9MM-V Motherboard
One long beep.
  1. Leave the memory slot closest to the processor empty and try booting again. Award bios 1 long beep is memory error as the first 64K of the ram stick closest to th processor is accessed first. since you have tried different ram in different locations, let's rule out the board.
  2. If that doesn't solve anything try a different power supply. Sometimes (Phoenix) gives a long beep when system board or power supply are bad.
  3. Now if nothing else has worked it is probably tour mother board.
May 16, 2008 | Abit KN8 Ultra Motherboard
Reboots at different times, some times windows logo is grayed out and hangs
its is possible that you have some bad memory search & download a program called memcheck 1.70 or later, and either put it on a formated floppy or burn onto a cd ,make sure that the boot sequence in the bios is set to go to that drive first
the pc will boot into this program and will keep running untill you stop it,if their are any errors it will show up ,you will need to establish what memory chip it is, if you have more than one chip.
it could also be a power supply, supplying iregular voltage.
also xp requires at LEAST 256 mbs to run badly, more is if you are using less than 256 mbs it will be the problem.
good luch
Mar 10, 2008 | ASUS P5P800-MX Motherboard
No display
check that your display card is seeted properly and your ram,if you have two ram chips remove the chip in socket no.1 and replace it with the other chip.
Nov 06, 2007 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Abit Computer-model:AN78GS  Motherboard Logo
263 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
