Question about Microsoft Visual Basic 6.0 for PC
How do copy a table from an access database in one folder to another access database in another folder through visual basic code
    Problem Solver:
  • 10 Answers
Simple method Open both tables (or create second) and copy each record from source to target through 'do while not eof' or 'for each' syntax.
Second solution create link in target DB for first table, and use SELECT INTO statment in SQL.
Posted on Mar 19, 2009
What is sql condition in visual basic?
sql is used for databases. Something like sql server, oracle, or access uses sql. It is a group of tables configured to reference eachother, so if you are programming in visual basic, you are trying to reference something on your sql server.
Feb 28, 2011 | Microsoft Xbox 360 Console
What is run time error '-2147467259(80004005)' how i solved it rewati nadan
"The Microsoft Jet Database Engine cannot open the file '(unknown)'"There are several causes for this error message:
  • The account that Microsoft Internet Information Server (IIS) is using (which is usually IUSR) does not have the correct Windows NT permissions for a file-based database or for the folder that contains the file.
  • The file and the data source name are marked as Exclusive.
  • Another process or user has the Access database open.
  • The error may be caused by a delegation issue. Check the authentication method (Basic versus NTLM), if any. If the connection string uses the Universal Naming Convention (UNC), try to use Basic authentication or an absolute path such as C:\Mydata\Data.mdb. This problem can occur even if the UNC points to a resource that is local to the IIS computer.
  • This error may also occur when you access a local Microsoft Access database that is linked to a table where the table is in an Access database on a network server.
  • Check the permissions on the file and the folder. Make sure that you have the ability to create and/or destroy any temporary files. Temporary files are usually created in the same folder as the database, but the file may also be created in other folders such as the WINNT folder. For additional information about how to identify which folder does not have the correct permissions and how to configure temporary files, click the following article number to view the article in the Microsoft Knowledge Base: 253604 ( ) Microsoft Access 97 database connectivity fails in Active Server Pages If you use a network path to the database (UNC or mapped drive), check the permissions on the share, the file, and the folder.
  • Verify that the file and the data source name (DSN) are not marked as Exclusive.
  • The "other user" may be Microsoft Visual InterDev. Close any Visual InterDev projects that contain a data connection to the database.
  • Simplify. Use a System DSN that uses a local drive letter. If necessary, move the database to the local drive to test.
  • Follow the instructions in the following article to work around this problem: 189408 ( ) FIX: ASP fails to access network files under IIS 4.0 and IIS 5.0
Oct 16, 2009 | Microsoft Access 2003 for PC
Access database was copied now no tables in dropdown list
Your version of Access may require slightly different menus and clicks than mine, but the procedure is straightforward and should be very similar to what you will need to do. Read the whole post first!
Make sure you have permission to modify the database, then go to the form (I assume the drop-down table is in a form) and go to design view.
In design view, click once on the dropdown box you are having a problem with, and a properties screen with several tabs should pop up; click on the data tab, and look at 'data source'. In the list look for 'row source type' to see if the source of your data is a) a table or a query, b) a value list or c) a field list. Most dropdown boxes use either a value list or data from another table or a query (based on a table).
Check the source of data by going down to the next line in the list titled 'Row Source' (this is the list on the data tab that popped up when you clicked on the dropdown box in design view).
If the source is a table/query type you should see some code in the Row Source box like "SELECT....". Without changing anything, click once immediately to the right of the box, and whatever source the rows are coming from should pop up--if a query, for instance, it will pop up the underlying query in design view.
You should be able to troubleshoot the underlying query to see why no data is given in the dropdown box.
Another point where underlying query or table is used: If the table was based on a query that pulls data from the records in the current database, the drop down list will be blank until new records are added so the query has something to list.
And if the source is a 'value list', the values should be included in the row source box below, separated by semicolons. If not you simply need to add them in.
If your source is a field list, go back to whomever copied the database and tell them you need help with the copy they gave you...
Sep 13, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
I want to programaticaly modify an SQL statement in VB6
If I remember correctly you need to call ExecuteQuery or something similar otherwise it does not update the database.
Jun 16, 2009 | Microsoft Visual Basic Enterprise Edition...
Write into excel format
Your code does not save in access format it just makes a copy of existing file. You need to open table by table and export data using csv format.
It can be done using access OLE to export, or
write some VB code to access the database tables via ODBC and save row data to csv file
Feb 17, 2009 | Microsoft Visual Basic Professional...
Convert my database from dpf to mdb
Use access to import external data. It can read dbf and create mdb
Jan 06, 2009 | Microsoft Visual FoxPro Professional...
Visual foxpro to access
you need to use a ODBC conexion to trasport your tables into table .dbf in fox
you need to copy tur tables to excel documents an then import in vfp
Jan 05, 2009 | Microsoft Visual FoxPro Professional...
Accessing data
Dear reader
Place an ADODC control on your form in VB.
In the properties of the ADODC control goto the TAB General.
click "Use Connection String. With the button Build you can point to your database.
Thats it.
With the following code you can connect to db:
With Adodc
.RecordSource = "SELECT * From YOURTABLE"
End With
Now you have the table in the adodc control.
you can now do this:
Label1.caption = Adodc.Recordset!YOURFIELD
YOURTABLE = the name of your table in the database.
YOURFIELD = the fieldname in YOURTABLE you want to show.
Kind regards Fred.
Jul 04, 2008 | Microsoft Office Access 2003 (077-02871)...
About visual basic coding
The standard way of creating a database using VBA, which can be modified to suit your needs is this--> Note: the code (wspDefault.CreateDatabase("Newdb.mdb"...), can be altered to save the database in a folder  such as "C:\NEWDB\text.mdb". sub NewDatabase()     Dim wspDefault As Workspace, dbs As Database     Dim tdf As TableDef, fld1 As Field, fld2 As Field     Dim idx As Index, fldIndex As Field     Set wspDefault = DBEngine.Workspaces(0)     ' Create new, encrypted database.     Set dbs = wspDefault.CreateDatabase("Newdb.mdb", _         dbLangGeneral, dbEncrypt)     ' Create new table with two fields.     Set tdf = dbs.CreateTableDef("Contacts")     Set fld1 = tdf.CreateField("ContactID", dbLong)     fld1.Attributes = fld1.Attributes + dbAutoIncrField     Set fld2 = tdf.CreateField("ContactName", dbText, 50)     ' Append fields.     tdf.Fields.Append fld1     tdf.Fields.Append fld2     ' Create primary key index.     Set idx = tdf.CreateIndex("PrimaryKey")     Set fldIndex = idx.CreateField("ContactID", dbLong)     ' Append index fields.     idx.Fields.Append fldIndex     ' Set Primary property.     idx.Primary = True     ' Append index.     tdf.Indexes.Append idx     ' Append TableDef object.     dbs.TableDefs.Append tdf     dbs.TableDefs.Refresh     Set dbs = Nothing End Sub
Hope this helps! Please let me know if you have any questions.Thank You,Raph30
Apr 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Microsoft Visual Basic 6.0 for PC Logo
182 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
