Question about Better Living SPP High Efficiency Home Heater, ...
I have a nordyne elec furnace just put in a new heat sequencer
And now the fan will come on in fan mode but on auto it wont also it wont heat when it went out the fan worked but no heat what else do i need to replace to make it work its cold in idaho right now
  • Betty Meyer Oct 05, 2011
    where do I find the model #
  • 659 Answers
You need to check the low voltage side to see if the t-stat is calling for heat. If it is, it is either the sequencer or a fuse to the heating elements (older model). But most likely the squencer. If you have a meter, you can check to see what side of the sequencer is burnt. Could also be a relay depending on the model number. If you get me the model number, I can send you a copy of the wiring diagram for the unit. This is the brand that I deal with.
Posted on Mar 16, 2009
Electric Nordyne Furnace/AC/with heat pump makes buzzing noise when turned on, registers do put out heat. Any ideas what is causing the buzzing noise?
is it only in heat? Possibly the heater contactor but I don't believe nordyne uses a contactor. could possibly be the transformer humming? many different strange noises come from units, may want to have it serviced.
Oct 10, 2017 | Heating & Cooling
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
I need a wiring diagram for a furnace Nordyne model # E1EH-012HA. the problem is, the fan will not run in heat mode. The fan works in AC mode and when the t-stat is set in manual mode. (fan) I found a...
you need to set either the switch on the back of the tstat to HE NOT HG or in configuration mode you want the "tstat controls the fan" not "equipment controls the fan" or ELECTRIC HEAT NOT GAS HEAT.
Blower motor doesnt always come on in heat mode
Yes if your creful. There is a sequencer inthe unit that operates the fan in the heat mode. It sometime sticks. This is due the moisture from the ac sweating. You van pick upa sequencer at HVAC parts house. Just wire back wire to wire and you willbe ok. Kill power to furnace first. Rus
Dec 03, 2009 | Refrigerators
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Feb 28, 2009 | Heating & Cooling
Fan relay or sequencer.
If it were the sequencer, the heat wouldn't come on at all but the fan would blow. It's the fan relay but it could be the t-stat again. If you get a power surge when the unit is running, it can short out that portion only but typically, it will short out either the heat or the cool side depending on what is running not just the fan.
Feb 28, 2009 | Better Living SPP High Efficiency...
Nordyne electric furnace heats up but fan won't come on when set to auto. Is it a relay switch. Have installed a new thermostat.
If the fan runs in the ON setting then you have a bad fan relay for the heat mode.
Did you install the t-stat before or after the problem?
If after, you have a bad fan relay.
Feb 21, 2009 | Heating & Cooling
Better Living SPP High        Efficiency Home Heater, ... Logo
133 people viewed this question
Top Better Living Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Better Living Pool and Spa Expert? Answer questions, earn points and help others
