Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
Hi, im geraldine and i forgot my password in linksys router
The model is WRT54G2
  • Geraldine Omaque Mar 02, 2009
    Thanks sanith. I think, im almost there.. but when i type in those default gateway numbers, i was being asked for my username and password. i think i need ur help again. Thaks so much.
  • Geraldine Omaque Mar 03, 2009
    the username and password u gave didn't work..
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
Hi Geraldine
If you have forgotten your wireless password follow these steps from a wired computer
1>Start->Run->CMD->Ipconfig
2>You'll find default gateway
3>Type only the numbers on your browser window or type in eg:: http://192.168.1.1 in the run window
4>You"ll see a router setup page opening up
5>On the left hand side under wireless you"ll see security
6> Click on that you"ll see a 10 digit or 26 digit no if it wep security or a password if it is wpa .
7> that would be your security key for wireless
Posted on Mar 02, 2009
  • Padmaksha Mukhopadhyay Mar 02, 2009
    Hi Geraldine
    This user name and password is for the router
    Default user name and password are
    Username: blank
    Password: admin
    Try this out
How can I change my router password?
There is a button on the router somewhere that usually requires either a pin or a pencil/pen to successfully press.
Look all around it and if you press the button, possibly hold it for a few seconds, it will reset to default settings.
To connect to it, either connect wirelessly if you know the password, or use ethernet to physically gain connection.
Once you're at least "connected" to the router by either method, open a new browser window and type in
192.168.1.1
to enter the admin settings. You can there set up either a WEP/WPA/WPA2 key, or change the administrator password. These are different things, and reading the instructions on the page should help clarify which you want to change.
Dec 20, 2011 | Linksys WRT54G2 Wireless Router
Password problems.
Depending on the type of router, you could have various defaults set, if you never changed them.
You can press the reset button somewhere located on the router itself, using a pen/pin/pencil, and then google your brand of router asking what the default password is.
If it is a Linksys, you could google "Linksys default password" or "Linksys default login" for example.
I need a password for my lynksys
IF you didn't set a password then at the login screen :
Login ... leave blank ( some models use the word admin)
Password admin
IF you set a password and forgot it you need to restore the unit back to defaults and erconfigure the router
To restore press the reset button using a toothpick or similar item. Its located on the back next to the WAN port connection
Jul 20, 2011 | Linksys WRT54G2 Wireless Router
I forgot the password to this router so I've reset
type 192.168.1.1 into your browser.
user name should be admin
password should be admin.
Jul 04, 2011 | Linksys WRT54G2 Wireless Router
Want to modify my settings
Documentation is at
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G2
But this page is way more helpful
http://www.pcwintech.com/wireless-setup-linksys-wrt54g2-linksys-firmware
From a browser enter 192.168.1.1
This should give you the web interface to your router.
Your interface should look something like this:
http://ui.linksys.com/files/WRT54G2/1.5.00/
To login leave user id blank and use 'admin' as a password (default)
Note that this model has at least 3 different variants and particulars will vary:
http://en.wikipedia.org/wiki/Linksys_WRT54G_series#WRT54G2
Jan 11, 2011 | Linksys WRT54G2 Wireless Router
I cannot access my WEP Hex Key, how can I locate it or reset it?
Connect to the router with an ethernet cable. Use a web browser and connect to 192.168.1.1 You should see a router home page. login as admin (default id= none/blank/null password=admin) These detailed instructions may help here http://nabtron.com/forgot-linksys-wrt54gr-password-how-to-reset-settings-of-the-router/180/ browse to the wireless/wireless security section and set up your WEP key. You can preview the web page layout here; http://ui.linksys.com/files/WRT54G2/ e.g. http://ui.linksys.com/files/WRT54G2/1.0.00/WSecurity.htm for you this would be http://192.168.1.1/WSecurity.htm
Jan 08, 2011 | Linksys WRT54G2 Wireless Router
Forgot my Network name (SSID) & or WEP key or WPA passphrase I purchasrg a Epson NX510 wireless multiprinter. I already have a Linksys WRT54G2 router
hi
go to following link you will find your solution for wireless issue
http://compnetworking.about.com/cs/wirelessproducts/qt/changessid.htm
Oct 07, 2010 | Linksys WRT54G2 Wireless Router
I forgot my router password and need to reset it
To reset your WRT54G2 router, locate the reset button at the left side of the rear of the router. Press and hold this button for 30 seconds. This will reset the router to factory default operation.
Apr 02, 2010 | Linksys WRT54G2 Wireless Router
Need securtiy key or passphrase for linksys to get internet
have you tried a hard reset?
or checked the 192.168,#.# ?
admininstartor
password or blank
Oct 15, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
205 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
