Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Beater bar stopped working
I caught the edge of a rug in the beater bar and it stopped working. I have pushed the reset button but it did not fix this problem. The suction still works- it's just that the beater bar no longer turns. Thank you!
  • Anonymous Mar 16, 2014
    how to fix?
  • 547 Answers
Hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
Posted on Mar 02, 2009
  • albert getty
    albert getty Mar 02, 2009
    hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
The "rug mode" (when you
pull out contents - gently off beater bar. Push reset button.
Sep 03, 2011 | Kenmore 25512/ 25513 Progressive Canister...
BEATER BAR WILL NOT WORK. I ACCIDENTLY RAN VACUM OVER SMALL THROW RUG WHICH GOT CAUGHT IN BEATER BAR AND IT STOPPED AND I COULD SMELL BURNING. I SHUT IT OFF RIGHT AWAY. WHAT DO I DO?
remove the bottom of the machine, and if your lucky re attach the belt, if not replace it , you need to remove the beater bar to do this, so prior to taking it out, look at the ends so you know where they are and the positioning before you remove it for easy reattachment
Jul 03, 2011 | Miele Vacuums
While using the power mate rug part I caught a small rug and the vacuum would no longer pick-up .
Check to see if there is a reset button on the head. This protects the machine for times like you described. When something jms up the reset button will turn ofdf th machine. Simply push the reset. Hope this helps, Chris
Feb 07, 2011 | Kenmore Vacuums
My roller do not spin
There is also a circuit protector which trips if something gets caught in the roller, so that might be the problem. There is a very small red button on the right side at the bottom of the vacuum (IT'S VERY TINY), and you just push that in and it will reset the circuit.
Aug 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Rug beater does not work, vacuum does I just was vacuuming the rug and it suddenly stopped, beater will not turn on.
The beater bar will turn itself off if something became lodged in the brushbar area - it turns itself off so that it doesn't cause any further damage. If this is the case, recline the machine, turn it on and press the gray button next to the red power button. This is the brushbar's ON/OFF switch. If that doesn't solve the problem, call the Dyson helpline for further assistance.
Jul 11, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater bar on singer central vac stops beating
try cleaning the ends of the brush roller. thread gets caught in there and jams it
Mar 07, 2009 | Singer Vacuums
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Noisy on rugs!
Are the rugs long haired or short haired? Most likely the suction is just causing the noise when it picks up the rug and the buzz saw could be the beater bar hitting the rug then. I actually own a DC14 and it does the same thing and the rugs like to be dragged along. Nothing really to fix this, just the way it is. You could try it with the beater bar raised and see how well it works then but this sounds normal.
Have a good day
bestdarngood
Feb 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater Bar/Brush Won't Turn
Sometimes dust,lint and thread can work its way into the bearings on both ends,take the beater bar out and see if you can turn it in your hand,if it doesn't inspect the ends and clean them.Use what ever you can find to pull out the threads.Or take it outside and hose it off.
Feb 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
446 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
