Question about RCA D52130 52" Rear Projection Television
Does anyone know if this tv is analog
Is tv analog
  • 905 Answers
The tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Posted on Mar 02, 2009
  • 4,234 Answers
To be more precise, this TV has a twin tuner that can receive NTSC signals only. The tuner is a digital tuner (tunes using numbers rather than a turning dial) and can receive both over air broadcasts in NTSC as well as cable or satellite broadcasts. It CAN NOT receive the new over-air digital (ATSC) broadcasts. Therefore if you reeive your TV signals over and antenna or rabbit ears, this set will require a converter box when the signals changeover in June.
Dan
Posted on Mar 03, 2009
I have managed to switch my LCD Philips TV from analog mode into digital mode. As I pressed the menu button it has gone into start up mode. Does anyone know how to get it back into analog mode without a...
You need a remote with the i+ button. Go into the service mode by pressing 062596i+ and put the set into factory mode and then select STORE. After a reset of the power the tv will be in the normal analog mode.
Do NOT change anything else in the servcie manu, it ruins your television!!
Feb 26, 2015 | Philips Televison & Video
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
Convert normal tv to hd tv
HELLO
If the set you are trying to convert to HD is just your everyday standard VHF/UHF analogue TV - basically forget it! I am given to understand you cannot make your standard telly show HD pictures.
Sorry! That is, of course, anyone else knows different.
Sep 20, 2009 | Televison & Video
Guide
This TV is analog, meaning there are no "straight digital" inputs, and the tuner itself is NTSC (analog), and not ATSC (digital). You will need a digital converter box to receive over-the-air (broadcast) digital television stations. This does NOT, however, preclude you from purchasing Digital Cable or Digital Satellite, and using the analog output on their converter boxes. The television will display high-definition images from those boxes and other sources.
I have the owner's manual in .pdf (adobe acrobat) format. Leave me your email address and I'll send it to you.
Thanks,
Rob
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Analog VCR
no you can use your regular VCR. You will just have to make sure you put your coverter box to bring the signal into your vcr. You can also bring the signal into your TV from the vcr so that you don't have to have 2 converter boxes.
Jan 23, 2009 | Memorex MT1134 13" TV
How can I get Freeview Channels?
I have a Bush 6690D and I can confirm that it does have a built-in digital decoder for terrestrial signals (Freeview).
Have you checked whether ***********'s TV is set to digital mode ? The "Mode" button on the remote cycles between analog, digital and AV inputs.
Oct 23, 2008 | Bush DVD2038 DVD Player
Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
Aug 04, 2008 | Philips Magnavox 20MT133S 20" TV
KD-36FS130 Digital Set-Up?
I did not know that the Sony FS series has digital capability. This is supposed to be the most basic model of CRT flat screen TV that Sony made.
You can get a digital cable or satellite box that outputs analog baseband or component analog video and analog audio. You can then connect this box in to the TV set. The TV will then display the analog signal from the digital box.
If your cable or sat box is able to tune in standard channels, but cannot tune in the ones that are on digital service, then the fault is with the box, or the cable or sat system. This you should address to the TV service provider.
Jerry G.
Apr 19, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
RCA D52130 52" Rear Projection Television Logo
170 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
