Question about Maytag Neptune MAH9700 Front Load Washer
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
Chime will continue to sound until power killed, water fills until manually shut off at valve, seems to occur near end of rinse cycle (according to bars on display). Never gets to drain/spin part of rinse cycle.
  • Anonymous May 20, 2009
    I have the exact same problem on the MAH9700AWW front loader washer. It continues to fill on rinse, code "OE" comes up and keeps filling until I manually shut off the tap's. I got a hold of a user manual on line with some diagnostic for "service mode" and I found the log of diagnostics. I also have "O3" code and don't know what it is. Can anyone help? I'm hoping to kill 2 birds with 1 stone..... for the "OE" fault, I replaced the water level sensor (top right) and still getting this fault. Please HELP!!!!!!
    LATICIA Jan 03, 2014
    mine stops filling on its own but it doesnt spin
If the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Posted on Mar 12, 2010
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Atlantis washing machine doesn't fill
maytag has had multiple problems with the neptune series (atlantis included) units. Test the pressure switch for function and continuity, and also make sure pressure switch tubing is free and clear of obstruction or pinching. Replace pressure switch or tubing if needed. Pressure control may be located in machine control board on some models, if this is the case and the tubing is checking good, replace the machine control, not the interface or motor control board, and then test. all should be checking ok.
Jul 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code ''oe'',
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual, it may not be there, they want a tech to come by to make more $). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course some direct the hose into sink, fine. Snaking out your standpipe would be good too.
Rate me nice or not at all. Happy spinning! Nice to watch the machine spin, not your head!
Mar 04, 2009 | Washing Machines
Water continues to fill
well, i'll tell you. take it back. i overheard a repairman say they are sorry machines. i wanted to buy one until i heard that last summer.
Jan 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer mod # MAH9700AWW shows a fault code of NF could you help in any way Thx
means no fill, continuous fill of 12 mins. generates this. check water valves. if you do actually have proper water flow in and are getting this then check level sensor. a full tech sheet is avail at with info on checking components.
Jun 03, 2008 | Maytag Washing Machines
Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Feb 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Water fill
Try unplugging the unit. If it stops filling you have a control board problem. If it continues to fill, you have a bad fill valve that is not closing properly, usually because of dirt or scale buildup thats gotten past the inlet screen on the valve. Good Luck!
Oct 05, 2006 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH9700 Front Load Washer Logo
1,060 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
