Question about Toshiba TP55F80/81 55" Rear Projection Television
WHERE CAN I FIND AN ORIGINAL REMOTE FOR MY TP55F80?
I SUDDENLY LOST THE CONVERGENCE ON THE LEFT OF MY SCREEN. IT DOESNT CHANGE HOT OR COLD THOUGH. IM TOLD I NEED THE ORIGINAL REMOTE IN ORDER TO RESET THE CONVERGENCE. DOES THAT SOUND RIGHT? EVEN IF SOMEONE CAN GET ME THE PART # FOR THE ORIGINAL REMOTE WOULD BE HELPFUL.
THANKS.
    Problem Solver:
  • 13 Answers
The problem is probably that one or both of the STK convergence chips have failed. These control the convergence coils around the red blue and green guns and are the most common cause of sudden convergence problems and the protection circuit shutting the TV down when turned on.
I can post details of how I replaced these on my Toshiba 40WH08B. Yours should be similar.
Posted on May 30, 2009
How to fix the convergence on a toshiba TP55D81 tv using the remote control
The convergence is adjusted with the remote by entering a tech menu and adjusting there====if convergence is really bad adjustments are not going to fix it.
The set should have in customer menu a limited convergence adjustment with up to nine points where you can adjust---if it will not adjust there in some way----convergence circuit needs repair.
Mar 16, 2012 | Toshiba TP55F80/81 55" Rear Projection...
Have aligned all the + signs already but is still out of focus!
with the original remote go into the customer menu and find CONVERGENCE---you will be able to adjust a single cross and also if you continue it will give you several points on the screen with a grid of lines----what you are looking for is does the red and blue adjust in all areas----if either will not adjust up/down and left right---you have a convergence problem--need to replace both convergence IC's and then align the convergence. Hope this helps you.
Aug 09, 2009 | Panasonic PT-51HX40 51" Rear Projection...
I have a 42'' where the color in the top left corner seems to have separated, or shifted. The picture is ghosted in red and green in this area. It happened all of a sudden.
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 19, 2009 | Akai PT4298HD Rear Projection Television
I just replaced the two convergence ICs in my Hitachi 53UWX10BA projection TV and it looks very good in the middle of the screen top to bottom, but as you go out both right and left the convergence gets...
Yes, it sounds to me like it only needs touch up in the tecnician convergence menu. Which you get into by pushing the service only switch after the set is on and then using an original Hitachi remote control to do the adjustments.
Jun 14, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Green Out Of Focus
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
May 30, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Tp55f80 tv. to much red on screen
You have a convergence failure. It may be possible to simply re-solder the pin connections under the convergence output ICs as they have a tendency to develop cold solder joints which cause intermittent mis-convergence. If the solder connections are good, then replacment of the ICs will be necessary. Expect to pay $350-450 to have a toshiba servicer fix this.
michtech
Feb 17, 2009 | Toshiba TP55F80/81 55" Rear Projection...
48wp30 ? How do i get to the service screen onb my remote?
Do you have the proceedure to adjust the convergence with the remote and the convergence menu?
May 24, 2008 | JVC AV-48WP30 48" Rear Projection...
Screen size is too big all of a sudden
im guessing it convergance amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
or
you can send them the board have it fixed
www.ptscorp.com
Dec 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba TP55F80 convergence problem?
check the convergence chips for bad solders or even the crt sockets, I would lean more on the ic's and surrounding area.
Apr 18, 2007 | Toshiba TP55F80/81 55" Rear Projection...
TP55F80/81 55 in
no mater what I say you will need a tech, is note that you dont have experiece with this tv, so let the job to a tech, is better for you...good luck
Aug 09, 2006 | Toshiba TP55F80/81 55" Rear Projection...
Televison & Video Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
