Question about Compaq (261671-001) Motherboard
Sys is getting power off with in 10 mins
When i am starting sys , with in 10 mins getting power off, what would be the problem.
    President:
  • 948 Answers
Overheating is the first thing I would check. Both in your system case and your power supply. It could be any number of things but based on the information you provided that what to check.
Posted on Mar 02, 2009
2007 Buick allure, 4 beeps every 5 min even when no power connected.
If you still get the beep with the battery cables off then you have another power source in the car. Did someone add an alarm sys. and install another battery or power source. I would check for that.
May 26, 2017 | Buick Cars & Trucks
What is wrong with my car?
Year make and model helps. Resetting the security is 10 minutes on and 30 seconds off. then start.
Feb 26, 2015 | Cars & Trucks
I don't have a cover for my fuse box and need to
Thanks for the inquiry.
Fuse Numbers and Locations:
EXPLORER FUSE PANEL Fuse Position Rating Circuit Protected 1 10 Amp Power Mirrors/Antenna 2 10 Amp Air Bag/Blower Relay 3 15 Amp Parking Lamps 4 15 Amp Left Headlamp 5 10 Amp On Board Diagnostic II System 6 15 Amp HO2S Sensors 7 10 Amp Illumination Switches 8 15 Amp Right Headlamp/Fog Lamp System 9 10 Amp EATC Mem./Seat Mem./Mess. Ctr./Cell. Phone 10 10 Amp EATC Sys./Rear Blower/Spd. Control/GEM Sys./Brake Interlock/OH Console Adapt. Susp. 11 10 Amp Warning Lamps 12 10 Amp Front and Rear Washers 13 15 Amp PCM Sys./Stoplamps/4WD/
ABS/Spd. Control/Trailer Tow 14 10 Amp Anti-Lock System 15 15 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 30 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 10 Amp Radio/Power Ant./GEM Sys./Anti-Theft/Cell. Phone 21 15 Amp Hazard Lamps 22 15 Amp Turn Signals 23 15 Amp Rear Wiper System 24 15 Amp Starter Relay/Anti-Theft 25 10 Amp Speedometer/GEM System 26 15 Amp A4LDE Trans/DRL Sys./Backup Lamps/4WD/Rear Defroster 27 15 Amp Under Hood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/Accessory Delay/DR Switch Illum./4x4 System 28 10 Amp Memory Seat/GEM System 29 15 Amp Audio System 30 - Not Used 31 10 Amp Aux. Blower System 32 10 Amp Heated Mirrors/Heated Backlite 33 20 Amp High Beam Lamps 34 10 Amp Audio System/Power Antenna 35 - Not Used 36 - Not Used
Hope this helps helps. Please keep us updated and remember to rate this answer.
Kind regards,
TF
Jun 05, 2011 | 1995 Chevrolet S-10 CA Edition
Will not start for 10 min can i bypass the pssslock sys.
Yes, very simple and cost effective alternative to a dealer repair on a failed system.. Look at this link for info and a solution to your problem. http://vatspasslockpasskeysecurityhelp.yolasite.com/
1995-1996 Impala SS 2000-2005 Impala
May 12, 2011 | 2005 Chevrolet Impala
My screen won't light up. When I start up, I see a very dim, reddish Toshiba start logo, and although everything else loads and starts up, the screen remains black. If I light the screen from the side...
Hi...
Its either a broken/loose wire on your invertor,or your inverter may have given up the ghost...they are easy enough to replace and quite cheap in ebay....just put the make and model of your laptop on ebay...and there should be plenty on there for anywhere between £10-30...and it,s about 30 min-60 min job depending on your experience
Apr 02, 2011 | Toshiba Computers & Internet
660, hangs up totally after ca. 40mins use
Hi Martin,
It sounds like a corrupted firmware update. Please go to this site:
http://gpsinformation.org/perry/nuvi/
I believe the latest firmware version for a 660 is v4.7. You can try reflashing the firmware with v4.7 or trying an earlier version. Let me know if this resolves your issue.
Also, the Nuvi can lag if you have large picture files on an inserted SD card.
- Jim
SHARCNET-USA
Feb 13, 2009 | Garmin Nuvi 660 GPS Receiver
Not turning on
take the batt out the sys. then put the charger. wait 3 min after that turn your sys on.
without the batt. if it turn on. your batt is damaged. if it dont turn on without the batt and
just the power cord is there. then your power suply node is broken or just no good.
if the sys goes on wait 11 min must 11 min exact. them put the batt on it and take the
power cord off. if sys stays on. your ok.
Dec 30, 2008 | HP Compaq NC6400 Business Notebook
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Sansa e260 takes 15 mins turning on.
once the blue circle is there, you just need to wait, it'll turn on
if not, take it to a best buy
May 05, 2008 | SanDisk Sansa e260 MP3 Player
Compaq (261671-001) Motherboard Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
