Question about HP Wireless Optical Mouse
Infared light on mouse
I turn my mouse on and the blue light flashes but the red LED light does not come on.
    Sergeant:
  • 270 Answers
Connect the cables properly
Posted on Mar 02, 2009
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
It won't sync
Click on the USB small button "after attach it to the computer" one click. While the red tiny led flashing - turn your mouse updown and hit the small button.
When the red flashing led stop - then you connected.
May 16, 2011 | Belkin Mini Wireless Optical Mouse...
My case logic mouse does not show up in the "find devices" area. batteries are brand new. I just want it to work.
I tried searching case logic's site for support for this mouse...but to no avail. Apparently this was a hit and run product they never looked back on. Anyways, I found a few answers from other users on the net. Here's one such solution I could glean. Hope it helps:
1) Locate the 'reset' button on the bottom of the mouse. (Tiny little black button on ours...)
2) Plug in the USB receiver. The blue LED button should light steadily.
3) Turn on the mouse. Hold it near the USB receiver.
4) Push the blue LED button on the receiver, and as it begins flashing slowly, push the reset button on the bottom of the mouse. This should synchronize the mouse and the USB receiver within moments.
5) If the blue LED button on the USB receiver begins flashing very rapidly, the mouse and the USB receiver are communicating, and the mouse should begin to work.
If it does not, the battery in the mouse may need to be removed and replaced, then the whole process started again...
If it works, you'll probably have to go into Mouse Properties in your Device Manager and adjust the response of the mouse, because the default settings are often positively crazy sensitive!
Mar 11, 2011 | Case Logic Computers & Internet
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
What is the syncing process for a logiteck wireless mouse
Take your wireless receiver that is connected to your computer and turn it over. There should be a red button. Press it once (propably a led light will start flashing). After you do that, take your wireless mouse and do the same. Turn it over and press the red sync button.
Your mouse should now be synced.
Feb 07, 2010 | Computers & Internet
LED light on mouse
change the battery,if it persist send it to survice center
Mar 02, 2009 | HP Wireless Optical Mouse
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Trouble pairing my bluetooth Macally BT micro mouse
HP Wireless Optical Mouse Logo
157 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
