Question about ASUS P4P800-E Deluxe Motherboard
The bios is not installed
I have just connect my new MB ,after starting for the 1st time,it comes up and shows this message,"No drive attached to fast track controller,the Bios is not installed"
is the any idea about it?
  • kukuyi Mar 02, 2009
    thanks for your solution it did not work
    by the way I didn't post any rating for you
  • 82 Answers
Go to BIOS, under Advanced > PCI Configuration. Disable Onboard ATA device if you're not using RAID. Also, make sure under Boot Menu that Other boot device do not show SCSI/Onboard ATA.
Hope that helps.
Posted on Mar 02, 2009
  • cool fixya
    cool fixya Mar 02, 2009
    Why did you gave me in appropriate rating ..plz tell me otherwise change the rating ....
Hi .... I tried to plug in an external USB drive that had previoulsy been attached to my PVR. Runnign Win 7 Ultimate. Got message about an INITIO driver being installed and then the drive access light...
is the usb drive still attached? if so, unplug it from the pc and see if this fixes the boot issue. If so, you most likely have your bios set up to boot from usb first. You can either change this order or remove the usb drive every time you reboot.
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Open link in new incognito window
  • Download file
  • Copy link address
  • Edit PDF File on PDFescape.com
Feb 26, 2011 | HP GX612AA Pavilion Media Center M8330F...
I just bought a harddrive because my old drive went. so I hooked up the new drive and turned it on, but i get nothing but a blank screen
hi there,
please unplug new harddrive and see if computer boots up without it.
if it does list all the other cd/dvd drives, then you did someth. wrong upon installing the new drive.hook up again, see the jumper settings in the back(must be set to single ) if attached to 1st IDE-channel, else if you hook it up to a cd-drive, set jumper on cd to master, onharddisk to slave, check power connection, reassemble pc, boot up.
Got a screen now? hdd should belisted! now insert windows installation cd and proceed...
if system still does not recognize the drive, then enter BIOS(press F2 or Del or F1 during booting)set all drive detection to automatic, leave saving BIOS-settings, press F10), reboot.
Problem solved?else come back on fixya.Good Luck
Sep 24, 2009 | Computers & Internet
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
Problem loading an OS onto a Dell XPS One 2010
YOU NEED THE BIOS UPDATE FOR THAT ,,GET IT FROM A ANOTHER CPU ,,BOOTABLE DOWNLOAD,,PUT IT ON THE DELL ,,THEN XP,,CHECK THE DELL WEBSITE
May 15, 2009 | Computers & Internet
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
Power supply runs, but no bios or boot
yes it sounds as the the cmos bios chip is damaged, if theres no bios showing, you will have to replace the mobo.
Sep 03, 2008 | Dell XPS 200 PC Desktop
IMPROPER SHUTDOWN OF DESKTOP PC
1st Try some different memory
2nd Try this remove all attachments to M.board hard drive cd dvd all except for memory and video card and try to boot
if it does install removed item one at a time and reboot and so on until you perhaps find faulty item
Check all cables to hard drive and
cd dvd are connected properly
Red or Blue stripe nearest the 4 pin power lead and they are set correctly master and slave etc
Aug 16, 2008 | ASUS A7V8X Motherboard
New sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
May 17, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
ASUS P4P800-E Deluxe Motherboard Logo
216 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
