Question about HP Pavilion dv6000z Notebook
Power problems power up and would stay on and then power off, when i go to power it back up it power off i hear the fan starting and when it does stay on the screen is black.
It looks like there is a problem with the video card which is part of the motherboard.
This is a manufacturing problem and HP is providing extended warranty for such issues. All you need to do is contact your local HP technical support people and say that you have this problem. Hopefully they'll cover it under extended warranty and replace the motherboard.
One thing you can try, take the power adapter and battery off. Press and hold the power button for 1 minute. Connect the power back and see if that helps.
Cheers
Posted on Mar 02, 2009
My friend karen press the power button, thre is no power... there blinking lights on the back of the computer near the fan power ...
Do you hear the harddrive start up? When you push the power button (or switch on the back) do the lights go out? If you hear fan running and hard drive start up then the computer itself might be on but the monitor isn't. Check the power to the monitor, the connection between monitor and computer to make sure they are all on and connected.
If you don' t hear the fan running then you have other problems. Any blinking lights would indicate something is getting power. I'm assuming the computer was working before the power button was pushed... If the monitor is actually working, you could hook up another monitor to check too then you have other problems but need more info to know what that could be.
would need to know the answer to the above questions as well as if it was working before, what was done, what changed between it working and this problem. Also what age the machine etc.
Jul 06, 2011 | Computers & Internet
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
I WAS HAVING PROBLEMS WITH OVER HEATING, NOW MY LAPTOP HAS CUT OUT AND WONT RE-START. WHEN YOU PRESS THE POWER BUTTON IT LIGHTS UP AND YOU CAN HEAR THE FAN OR SOMETHING BUT THE SCREEN STAYS BLANK. ALSO...
When a laptop overheats the CPU will shutdown, this is known as thermal overload. The laptop will not boot up until the CPU has cooled down. If this problem in not fixed then the CPU will eventually fail.
This problem is usually caused by a faulty fan or the fan and heat sink is clogged with dust.
Replace the fan if it does not spin freely and or remove the dust clogging the fan and heat sink.
Oct 27, 2010 | Compaq Presario CQ60-220US PC Laptop
Side by Side Model # ED5GTN It is not staying cold - freezer let everything defrost and fridge not staying cold.
Open the freezer door and listen for the freezer fan . If you do not hear the fan , tap on the refrig thermostat knob mediumly . If the freezer fan comes on , then the thermostat is bad , pt # 2198202 which is located behind the knob . If you DO hear the freezer fan , then the overload / relay on the compressor is bad which is pt # 8201786 ( comes with instructions ) . Both are easily repairable . If any problems , reply back for more help .
Aug 03, 2010 | Refrigerators
5N32 SLI SE Deluxe board no POST
Check your power supply voltages. All of them!
You can find a list through google for connector pins.
Look for ATX power connector.
Apr 26, 2010 | ASUS P5N32-SLI Deluxe Motherboard
Computer light will stay on but cant get any power up ?
Several things to check. First, is the fan spinning on the power supply? You can detect this from the back of the PC. If it is not, then the power supply is bad. Also, if you can, remove the side p[anel and power up and notice if any of the fans are spinning or do you hear any evidence of booting, beep codes, etc. If the power supply fan is spinning and you hear nothign inside, the motherboard could be the culprit.
Nov 21, 2009 | Computers & Internet
My Apple screen stays black!!!!!
If you hear the fan spinning and the screen stays blank chances are very good that the video chip on your logic board has failed. That was a common issue with many Apple laptops of that generation.
Before you give up on it however try resetting the power manager and reseating the RAM. Below is a link to instructions on how to reset the power manager on a powerbook.
http://support.apple.com/kb/HT1431
Aug 31, 2009 | Apple PowerBook G4 Mac Notebook
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
Wont stay powered up
plz check with a new power unit if the problem remains then *********** board needs servicing
Jan 13, 2009 | Compaq Presario S5100NX (E120866) PC...
Power steering problem
it is not the pump that stays on its the fan if your hearing a wizzing sound that starts off low and progresses high very quickly. this stops when u turn ur car back on and continues once off but leave it off for a little while and it should stop i believe its a fan because my friends cobalt does the same thing
Oct 08, 2008 | 2003 Mini Cooper
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
