Question about Moen & One Handle Tub & Shower Faucet
Are the steps the same in changing the shower cartridge and bathroom sink cartridge?
  • 547 Answers
Yes make sure you shut off main water and open basement drain off
Posted on Mar 02, 2009
2 Suggested Answers
  • 374 Answers
SOURCE: leaky shower knob
Absolutely the same as the shower excluding the obvious difference in supply cut offs.Thanks for using Fix Ya.
Posted on Mar 11, 2009
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
No cold water to shower but have it in the sink could it be in the valve?
The shower valve is probably pressure balanced, meaning it is anti-scald. Depending on the make of faucet you either need a new balancing spool or a new cartridge.
Jul 06, 2014 | Home
I have a posi temp faucet that has been installed for 6 years but never used. Now i have the project completed and have no water pressure thru the shower head. The sink has lots of pressure and is on the...
Have you disassembled the shower head to see if it has a flow restrictor in it. If it does you can remove it and any aerator type screens. Hope this helps. Thanks
Dec 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
No hot water in shower but have hot water in sink
Is your shower valve a single handle. If so I would reccomend you change cartridge. To do this shut off water to valve or house. Remove center cover on valve handle,most of these are just friction fit so gently pry off with knife point or small screwdriver. Remove handle by pulling straight out,then remove chrome cover that fits around outside of valve. Ther is a small copper retaing clip that holds valve in place. It should have a small hole in tab that is on top of valve. Grasp this with pliers and pull up to remove. Then remove cartridge by pulling on cartridge stem. If it's doesn't come out you can get a moen cartridge puller at hardware store. Remove old cartridge,install new one and reinstall retaing clip. Reinstall chrome cover and handle.Turn water back on and try shower valve to see that cold is on the right side. If it's not remove handle and turn center stem 180 degrees.This will change cold side to right. Put handle back on with cover and you sould be done. Hope this helps. Thanks
Nov 19, 2010 | Moen Home
Bath tub water doesn't stay hot
it is because the tub has a temp control valve in it so if you were to put more cold with the hot it will last longer but still won't be all the way hot,, now a days people are suing the manifacture because they are getting burned form the hot water so they put these saftey temp controls in place of the old style 2 or 3 handle faucets,, there fo no more real hot water nothing you can do outside of change to the othere type of faucet 2 or 3 handle tub shower diverter,, that why the water is hot in the sink but not the tub.....
Jun 23, 2009 | Water Heaters
Leaky shower knob
Mar 02, 2009 | Moen & One Handle Tub & Shower Faucet
Hot at showers but not at sinks
Do your sinks have a hot and cold handle or just one handle. how old are the faucets. If they are very old.the first thing i would do take one faucet out and replace cartridge.
Jan 22, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
Moen & One Handle Tub & Shower Faucet  Logo
99 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
