Question about Moen & One Handle Tub & Shower Faucet
Leaky shower knob
Are the steps the same in changing the shower cartridge and bathroom sink cartridge?
  • 374 Answers
Absolutely the same as the shower excluding the obvious difference in supply cut offs.Thanks for using Fix Ya.
Posted on Mar 11, 2009
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
How to fix bathroom shower faucet
shut off water to shower, remove knob by popping cover off and removing screw, remove valve cover by just pulling straight out. there will be a retaining clip that holds cartridge in you will need to remove, Pull out old cartridge and replace with new.
Feb 21, 2014 | Moen 3175 Legend One Handle Shower Faucet...
We bought a home and our spare bathroom shower does not work. we replaced the moen valve and still cannot get water to come out of the shower. the toliet and sink in that bathroom work as they should. and...
did you install the valve sideways or upside down? or is there a blockage in the hot line? the valve may be pressure balanced so if there is no water then there may be a blockage on one side. did you solder the valve? if so did you remove the cartridge? when you replaced the cartridge did you grease it with non-petroleum grease?
Dec 03, 2010 | Moen & One Handle Tub & Shower Faucet
Very loww water pressure when taking a shower, I've changed the shower head,but, water pressure continues to be low. I've got moderate water pressure in the face bowl in the bathroom and good to moderate...
It could be debris in the cartridge at the tap itself. Whther 2 cartidges or 1 , it wouldn't be uncommon for those to clog up as well, and it really doesn't take much to cause a decrease in flow. Turn water off to tap(s) and remove handles, then cartridges in behind with proper socket or wrench and inspect for debris inside hole cartridge came out of, as well as the cartridge.
Dec 29, 2009 | Home
Need to clean single knob shower cartridge from what i read - where do i shut off water first? hot water running to bathroom - sink gets it - in shower, cold water good, hot water trickles - read lots of...
To clean it, shut off the discharge valve at the water
heater. Then, you shut the valve off of the main water supply. After which, you can start cleaning the single
knob shower cartridge. After the cleaning job, you can
open the discharge valve of the water heater, then, the
valve of the main water supply.
Nov 11, 2009 | Moen & One Handle Tub & Shower Faucet
Moen & One Handle Tub & Shower Faucet  Logo
251 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
