Question about Canon PowerShot A540 Digital Camera
Diagonal lens cover will not open, or partially opens
It will open with slight pressure to opening with my finger nail.
  • 1 more comment
  • slfrear Mar 02, 2009
    I don't recall my camera falling. I don't know exactly when this started. I remember some images showing the camera lens partially open. Now, it has apparently become a constant problem, and requires that I delicately pry the lens cover slightly and it will open.
    Or I can gently jar the camera against the heel of my palm and it will makes it way open on its own.
    Thank you, I'll look for that Canon Service Center.
  • Sachin
    Sachin May 11, 2010
    Did the camera fall?
    If yes, then its possible that the alignment of the cover has been shifted.
    Novelist:
  • 98 Answers
I think you camera must have either banged against something or fallen.
You are lucky that you are still able to take pictures.
The best solution is to take your camera to the Canon Service center in your area. If you good with small screws then you could probably open it and check the barrel if it is rubbing/scrapping against something and align the same. If not, then its best left to the experts. Personally I will avoid opening the same and goto the camera center..
Best of Luck...
Posted on Mar 02, 2009
Cannot open battery compartment on remote
Either push the finger / thumb indentation down and along remote or release the small catch at one end of the cover using finger nail and lift the cover off with same finger nail
Jan 12, 2016 | Televison & Video
Partly open lens
the mechanical part that is trying to open the lens cover is having a problem
Possibly
1. a lodged piece of foreign material
2. A broken piece within the camera is interfering
3. A piece in the camera that helps control the lens or another piece by the lens is out of place
Please check this out if you are comfortable doing so and let me know what comes of it
Thank you
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
My lens won't retract or open and beeps 3 times and shuts off
I had a Polaroid i531 that would beep 3 times then shut down & the lens wouldn't retract.
I fixed it like this:
  1. Inspect the lens from all angles and you'll see that the lens assembly is out of sync. (My was looking upward ever so slightly)
  2. Using gentle finger pressure, press in the opposite direction of the abnormal lens direction
  3. I heard a snap, then I powered the camera on.
  4. Camera now works.
May 15, 2008 | Polaroid i531 Digital Camera
Lens problem?
This sounds like your automatic lens cover on the front of your lens is sticking. If this happens, take a look at the front opening of your lens to confirm this (it's very obvious). If so, try the simple fixes listed here (don't open the front if you can avoid it):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
May 10, 2008 | Canon PowerShot A510 Digital Camera
The lens will not open up or retract.
Apr 15, 2008 | Polaroid i531 Digital Camera
My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Mar 15, 2008 | Canon PowerShot A520 Digital Camera
Sony Cybershot DSC-W90
I had the same problem, I gently pried open the black windows of the shutter with my index finger nail, and applied very gentle pressure (pulling outward) while I pressed the power button. THEN... the whole zoom assembly moved EVER SO SLIGHTLY. So, I repeated the exact same process, with a little bit of pressure... and voila... the lens assembly opened fully and I was able to take pictures.
Jan 14, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
Shutter problem with a sony dsc-w30 camara
Make sure the battery is strong and not failing you and that the extending lens cover parts are clean. You may have gotten something in there.
Dec 24, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens Cover will not open or close
OMG! I had the same issue and blew on the lens. To easy to be true, but it worked! I thought maybe it was a fluke, so I turned the camcorder on and off several times, and it worked every time! Sure beats the $341 Sony was going to charge to fix it!!!!
Aug 23, 2006 | Sony Handycam DCR-DVD403 DVD Camcorder
Canon PowerShot A540 Digital Camera Logo
429 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
