Question about Adcom GFA-5802 2-Channel Amplifier
Can you bridge an adcom GFA-5802 power amp?
I own 2 adcom 5802s. I would like to buy 2 more and bridge them to run 1 per speaker just to power low frequency drivers. Is it possible?
  • 4,234 Answers
Running an amp in bridge mode requires a specific circuit design. It is not possible to combine 2 amps in this fashion.
Dan
Posted on Mar 02, 2009
I want to bridge 2 adcom GFA 555 amps to my sony DA7ES any suggestions
Obviously you are going to use the Front pre-out's on the Sony to drive the Adcoms. its pretty straightforward, just do not use a speaker that is less than 8 ohms. and make sure that you always have the power switch off on the adcoms, let them sit off for 5 minutes, THEN hit the bridge switch on the back of the adcom's and follow their instructions for bridging. it's pretty easy and tough to go wrong. Good luck...Rob
Apr 18, 2015 | Adcom GFA555 Amplifier
Can I run two stereo amps from same preamp?
yes, and do tell, what speakers are you powering with these amps?
Jul 09, 2013 | Bose 901 EQ1915 Home Equalizer
Adcom amp 5802 running hot
It should run hot to touch at idle, about 120F, because it is MOSFET type amplifier.
Mar 23, 2013 | Adcom GFA-5802 2-Channel Amplifier
How do you connect wiring to bridge an adcom gfa 5300?
The manual does not specify a bridging option.
http://www.audioreview.com/cat/amplification/amplifiers/adcom/gfa-5300/prd_116265_1583crx.aspx
"Weaknesses:
Not bridgable."
Generally an amp that IS bridgeable uses the positive speaker terminals and some switching method to tell the unit to run as bridged. This is NOT a recommendation to try it on the 5300.
Aug 02, 2011 | Adcom GFA-5300 2-Channel Amplifier
Is a Adcom GFA-7500 5 channel power amplifier bridgable?
no this AMP is not bridgable to get more power out of this amp you need 4 ohm speakers.
Power rating
1 - 150 watts into 8 ohm speakers
1 - 225 watts into 4 ohm speakers
Feb 23, 2011 | Adcom GFA-7500 5-Channel Amplifier
Adcom GFA 5500 'mechanical' hum from amplifier
Possibly. Most amps filter out line hum via low-pass filters. If you can locate a schematic, those would be the caps to check.
Apr 24, 2010 | Adcom GFA-5802 2-Channel Amplifier
I turn on the ADCOM GFA-5802 amplifier... ...The power light comes on, but does not heat up nor output sound
Have it serviced. Do you know what GFA stands for. People at Adcom do have a great sense of humor. Take it only to a high end audio servicer. Contact Adcom. This is good stuff you wouldn't want a hack working on it.
Nov 23, 2009 | Adcom GFA-5802 2-Channel Amplifier
How do i bridge an adcom gfa 5400
This amp is not designed to be bridged and can not be used in the mode you wish. Sorry, but internal circuit changes would be necesary for the amp to work as a single channel.
Dan
May 01, 2009 | Adcom GFA-5400 2-Channel Amplifier
ADCOM GFA 5802 POWER AMP NO SOUND, BUT POWERS UP.
Remove the output transistors and measure each of the sets of 3 pads and report the voltage readings here. I suspect that you have either a blown driver circuit or output transistors. The voltage readings will give me an idea on where to start looking for specifics.
Thanks,
Dan
Nov 11, 2008 | Adcom GFA-5802 2-Channel Amplifier
Adcom GFA-5802 2-Channel Amplifier Logo
507 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Greg Cann
Greg Cann
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
