Question about RCA D52130 52" Rear Projection Television
Still can,t find fuses in back amp 250v and 6.3
They say its near the plug cant find it please help 52hdtv rca d52130
I have only found one fuse on this, but there's probably others. The one i found was to the left and behind the plug. you have to take off the black plastic covering the plug, and all the other connections. You can see the fuse if you look between the bottom of the vertical and horizontal circuit boards in the corner.
Posted on Mar 13, 2009
I have a rca rtd255 home theatre system with two blown fuses. fuse one has 5s3a 250v and fuse two has 5s2.5a 250v written on them. I cant find these fuses. where do i find or what can i replace with
The fuses in question probably are 5 millimeters in diameter by 20 millimeters in length. You might be able to find them at Radio Shack but they also might have to be special ordered.
Sep 26, 2014 | RCA RTD255 System
Won't turn on
Unplug the unit , leave it unplugged, after an hour remove the top cover, look for a fuse near where the power cord enters the unit
. it will be near the power transformer and labeled F1 they are usually 4.5amp 125/250v. the reason for powering the unit down and leaving it off is to let the power capacitors bleed off.some fuses are in holders and some solder in. Hope this helps. If the unit has a bar code anywhere on it you can read the bar code with an app for cell phones and get all the info there. Also try schematicsunlimited.com
Apr 29, 2014 | RCA RTD615I 5.1 Home Theater System - 600...
Behringer Fuse Holder for B212A
I realize this is an old question, but if anyone else has the same query, from page 6 of the manual listed below, the fuse holder is located on the back panel between the power on switch and power socket. For use on 120v supply, 5 amp/250v. For use on 240v, 2.5 amp/250v.
-Steve
http://www.behringer.com/assets/B212A_P0261_M_EN.pdf
Oct 24, 2013 | Behringer Eurolive B212A Speaker
Hi There the fuse just blew in one of my Samson
Hi there
To answer your question;
If it is not indicated near the fuse holder then look closely at the metal end caps of the fuse.
The value will be written on one of them,
It may look like 2A/250v for 2amps.
Hope this help
Cheers
Jun 14, 2010 | Samson Resolv 65a Main / Stereo Speaker
Fuses for P-07
the fuse you need is a t4al 250v
this is a common slow blow 250v 4amp fuse.
You can get them at RadioShack
Oct 03, 2008 | Gemini Sound Products P07 2-Channel...
Rca d52130 herd pop tv went dead
dear friend your tv has a defective fly-back transformer 99 times out of 100 that is your problem.
get the model number and call your local electronics parts distribuitor to see if they have it, if not call tritronics 1800-638-3328 they probably have it and is not too expensive.less than $25.00.now when you get here is the million dollar question can you do it yourself? if you can't call the repairman and by having the fly-back that will decrese the cost of the repair, is just the labor.
good luck
caypianan@yahoo.com
Sep 02, 2008 | RCA D52130 52" Rear Projection Television
My tv did not come back on after a power cut could it be the fuse
Good Day;
After a power outage it is best to 'reboot' the TV. Unplug the TV for 4-5 minutes from a/c outlet, wait, plug back in. Did not work?
It could be the main fuse, it will be located near the a/c cord on the TV's board. CATION!! After removing back of unit make sure the TV is unplugged from the a/c outlet and the fuse will be a glass fuse, ensure that it the correct value eg; 5 amp 250v.
Good Luck and Careful, Big Irish.
Jun 18, 2008 | Televison & Video
RCA D52130
the fuse should be located right near where the power cord plugs into the chassis
Mar 28, 2008 | RCA D52130 52" Rear Projection Television
RCA D52130 CHASSIS CTC211A PROBLEM
Do you hear a click when you try to power it up? If no you may have a blown fuse. But if the fuse is blown chances are a short has caused that condition. Check the fuse to see if its blown and let me know and I will try to help you out with it.
Mar 27, 2008 | RCA D52130 52" Rear Projection Television
RCA D52130 52" Rear Projection Television Logo
294 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
