Question about Amana NED5500TQ Electric Dryer
Kenmore Dryer is partial drying
I have a Kenmore Dryer (Series 90, Model: 110.76912691, Purchased May 1998) that is partially heating. I cleaned out lots of lint from all parts of the dryer that I could access. I confirmed that the new dryer vent pipe (installed 15 months ago) was clean. What could the issue be? Why is it partially drying. 120 mins to dry what used to take 40 mins. What would you recommend? Fix it? Buy a new one?
  • 686 Answers
You'll have to check your thermostats. one is the dryer cycling thermostat and the other is fixed high limit thermostat this one is rated at 250 degree F. go to www.repairclinic.com/Appliance-Parts?s=t-11076912691-%3d%3d&z=100 Look for item # 2893 and 2926. This will show you which part to look for in your dryer. You may have to take the drum out to see these parts and while you have it apart clean behind the drum. to open you dryer you either pry the top up with a flat screw driver or at the bottom of the front panel there may be a couple of screws take them out and raise the bottom out. the top part should then lift off. Good Luck.
Posted on Mar 02, 2009
Kenmore soft heat series 80 dryer only partially dried my clothes
The most common cause for partial drying is a clogged vent hose. Make sure you have a clear airflow all the way out and clean the hood of the vent outlet - the flapper should be free to move up and down. If this doesn't solve the problem, you should have it checked by technician,
Oct 15, 2015 | Kenmore Dryers
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Dryer shuts off before dry. not dry.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 06, 2011 | Kenmore Elite HE4 Electric Dryer
My kenmore elite dryer is only 1 year old and does not seem to get hot and takes long time to dry clothes
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Dec 12, 2010 | Kenmore Elite HE4 Electric Dryer
The heating element in my Kenmore dryer, model number 110.63032101, does not fully heat up sometimes. With the setting on cotton/high the element will sometimes be fully illuminated and sometimes only...
no,that's how they run,if your clothes are drying and the dryer is cycling on and off,leave it alone,if the clothes are taking a long time to dry clean out the duct that the lint filter slides into and blow out the vent line with a leaf blower if it's a long run
Oct 12, 2010 | Kenmore Dryers
My kenmore Electri Dryer is humming while drying.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.hope this help you out sincerely D.Jones
Jun 08, 2010 | Kenmore 64672 Electric Dryer
Kenmore elite gas dryer is not drying clothes but the dryer is running no warm air?
Hi, Do make a check of these:
  • Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
  • Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
  • Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Apr 17, 2010 | Kenmore Dryers
Propane dryer. Can hear the heat kick on but dryer doesn't heat
Try looking at the gas regulator. It should have a solenoid that opens and closes. It sounds to me like this is not opening or is only opening partially. I had this same problem on an oven.
May 31, 2009 | Kenmore Dryers
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Amana NED5500TQ Electric Dryer Logo
117 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you an Amana Dryer Expert? Answer questions, earn points and help others
