Question about Watts Onan Portable Generator - 4000 , Model# 5500
Onan microlite 4000 generator no output
Loaned rv to friend,when returned,eng.runs good but has no ac output.
  • Anonymous Mar 30, 2014
    quits under power when rv drives down hwy
  • 257 Answers
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Posted on Mar 02, 2009
Onan 7000 generator runs but does not produce electric to rv
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
Mar 19, 2014 | Watts Onan Portable Generator - 4000 ,...
How to fix onan 4000 that will not stay running
Check the slips rings and brushes, check the stator and rotor windings for continuity and for shorts to ground. Check PCB plug connections. After that you need a new control board
Jan 07, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Have a onan 4500 watt generator on a bucket truck. i have no output at recepticles, can you help.
Onan units have a breaker switch on them that has to be in the right position or you get no power. Can't tell you for sure where it is on the 4500 but on the 4000 RV series it is tucked in behind the on board start switch
Mar 03, 2010 | Watts Onan Portable Generator - 4000 ,...
RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Aug 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
1,697 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
