Question about LG LFD25860
LG GR-292R freezer works/fridge does not.
Hi there.I have a LG Electrocool GR-292R.Weird thing is going on here. Freezer is working great....but the fridge part is quite warm. It is out of warrenty and LG refuses to help me out.Can you please help me out? I cannot find ANY information on the net about this model number of LG Fridge.
  • Digikid2009 Mar 04, 2009
    forgot to add.....the 3 little green lights in the fridge section are always blinking in tandem.
  • Digikid2009 Mar 05, 2009
    If that were the case then the freezer would not be working either.
Well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
  • 400 Answers
It is more than likely short of refrigerant, needs to have the leak repaired and then recharge refrigerant.
Posted on Mar 05, 2009
  • Shane Seaman Mar 06, 2009
    You can try this, close the freezer door (fan operation controlled by a small switch on the door) then feel how much airflow is getting to the fridge side. The fridge cooling comes from the freezer side through a damper which is closed or opened by the setting you make in the fridge compartment. If there is reduced airflow, it could indicate that there are problems with the defrost system or the actual defrost element. The green lights indicate that you are not within the differential range of the setpoint temperature. Hope this is more helpful
I have LG Electrocool GR-252SQ(Double door).the freezer is very cool but the lower fridge section is not getting cool.Plz guide.
i have same fridge and my problem is that the water from freezer is not going out pf the fridge, instead it comes down to fridge section through condensation
Mar 24, 2013 | Refrigerators
The motor starts, the fan works, no freezing, just slightly cool air coming from freezer compartment, changed relay, problem persists LG electrocool Model GM 3138c
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 30, 2011 | LG Refrigerators
Mylessthan 2 year old fridge just quit working-what could it be?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Mar 02, 2011 | LG Refrigerators
LG Model GR-B429BLQN not getting cold.
Refrigerator
heatman101
Feb 24, 2011 | LG Refrigerators
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Fridge gets cold then shuts off
Feel the motor temp. after letting it do its thing for a reasonable period. If motor is extreemly hot then it means motor is switching off on internal protection.(has to be replaced then.). Set temp to its coldest then see if it still switches off as it is. if the same, board is more likely to be a problem. Very seldom if ever does one have to replave sensors. (assuming it has an electronic board). If using a th/stat, replace it if temp does improve but still eratic.
Sep 16, 2009 | LG Refrigerators
I have electrocool LG MOdel# GR-382R ser# 206MR17803. my bottom fridge cooler area is freezing up.
I have the same problem.It seems that the gasket around the freezer door and fridge door are no longer tightly adhering to the fridge therefore allowing the cool air from the freezer to continiuously entering the fridge storage and making evreything freeze up. I am trying to find out if I can purchase new gaskets and install them myself.
Any recommendation on where to find these and how to install them?
Thanks.
Jun 22, 2009 | LG Refrigerators
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
LG LFD25860 Logo
2,092 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
