Question about Tappan MGF500PBW Gas Kitchen Range
I have a daughter with a four year old son. They live in an apartment with a pilotless gas stove. I am afraid at his age and curiousity he will turn on the gas and cause a buildup of gas which could cause obvious problems. Is there a safety factor built into this type of stove. Thanks, Dave
  • 8,197 Answers
Sorry to say there is no safty onthe stove. If you would like pull the handles off. They just pull straite to you. That is what I did with my son.
Good Luck and Please rate fixya!
Posted on Mar 02, 2009
I just turned on our pilotless oven and noticed the smell of gas. Turned it off naturally. The stove worked fine earlier in the day.
You could have a weak ignitor which can cause a smell of gas, I would have it checked unless you have a way to test for amperage. Test with amp probe should read 3.2 -3.6 amps if less than 3.0 replace ignitor. I hope this helps.
Good Luck
Jul 31, 2014 | Maytag CWG3100A Gas Single Oven
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
Igniter knobs on my gas stove turn just enough to let gas escape.
There isn't much you can do to the stove outside of buying a stove that has standing pilots or shutting off the gas each time you leave the kitchen. This is a problem with the pilotless design. If the knob isn't turned far enough the activate the spark switch, gas can escape without being lit. Vigilance is your only answer outside of the solutions suggested.
Apr 28, 2013 | Kitchen Ranges
"quadratic function" diophantus , a greek
Let x be Diophantus' age when he died.
His son died 4 years before Diophantus (so Diophantus was then x-4 years old). His son lived half as long as Diophantus so when he (son) died he was x/2.
Diophantus' son was born when Diophantus was (x-4)-x/2 years old. That was 5 years after his marriage so when Diophantus married he was (x-4)-x/2-5 years old. We also know that 1/6 of his life was spent in childhood, 1/12 in youth and 1/7 as bachelor so (x-4)-x/2-5=(1/6+1/12+1/7)x.
Now you solve last equation:
  • x-4-x/2-5=11/28x
  • x/2-11/28x=4+5
  • 3/28x=9
  • x=9*28/3=84 years
Diophantus was 84 years old when he died.
Sep 27, 2011 | Office Equipment & Supplies
How do i turn the pilot light off. I want to use a bug fogger in my apartment and i want to temporarily turn off the pilot on my stove
This model should have pilotless electronic ignition.If you hear clicking when you light the burners , it is electronic,. Also , open broiler drawer and turn on oven .After a few seconds do you see a glow start?Thats your electronic oven igniter confirming you have no pilot.
Was this helpful?
Aug 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
I have a General Electric auto pilotless ignition oven, model# jgcc58 eh5ad. when I turn on the bottom oven the igniter glows but the flames dont ignite. Can this be fixed by a modern igniter as this stove...
www.a-1appliance.com
FOR 45 YEARS OLD IF YOU HAVEN'T HAD ANY OTHER TROUBLES REPLACE THE IGNIGHTER AND YOU SHOULD BE IN GOOD SHAPE. A NEW IGNITER RUNS AROUND 75-80 DOLLERS.
THE IGNITER HAS TO GET HOT ENOUGH TO OPEN THE GAS VALVE, IF THE IGNITER IS FAILING OR WEAK THE OVEN WILL NOT LITE.
Feb 05, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove makes clicking noise when turning on
When a gas stove is clicking, it means it is trying to ignite the burner. If the knob is held in the ignite position for more then 3 seconds and the burner does not ignite, it means that (1) the gas is shut off to the stove, (2) she does not have gas service set-up yet at the apartment, or (3) the gas nozzles feeding the burner are dirty and clogged.
Most of the time, when you move to a new apartment, you need to call the gas company and have the gas turned on, unless it is included in your rent. Either way, when a house or apartment is unoccupied, the gas is turned off for safety reasons. I would contact the landlord to be sure.
Mar 22, 2009 | Stoves 600SiDOm Gas Kitchen Range
Age problem
Let x= the age of the son.
Therefore 8x=4(x+4)
Then 8x=4x+16
4x=16
x=4
Son is 4
Daughter is 8
Father is 32.
Dec 10, 2008 | Computers & Internet
I live with an old Roper Pilotless Ignition Stove. It has three vertical dials on the front betwen the main ingition knobs to control the Clock, the start time and the cooking hours. When I cleaned the...
Jkfiction
Hello, welcome to fixya ,
I understand the problem.
Do not let the owner, try to blame you.The problem is the landlord !
Most landlords say this to the renters and will never want to spend a nickel to fix or god forbid replace the range with a new one for 25 to 30 years.
What is the model # of the range.
Here is a report that I recently read.
You can tell him this was in n consumer report!
Repair or replace?
When to pull the plug on your old range
It nearly always makes sense to undertake simple do-it-yourself repairs.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your range,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your range is under warranty or less than four years old ,
paying for a repair makes sense.
Note that ranges under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your range is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new range.
Data also shows that it doesn't pay to fix a less-expensive range
7 or more years old.
Thanks to better recycling programs, less than 10 percent
of a range you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 25, 2008 | Roper Kitchen Ranges
Tappan MGF500PBW Gas Kitchen Range Logo
100 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
