Question about Asrock 775i65G Motherboard
On cpu three beep no disply ihave change ram but problem not slove
Posted on Mar 02, 2009
I have my asus p5vd2 vm se mother board when i power on it wont boot
Issue : Computer is not booting
Solution --
There could be many more resons of your problem
1) there might be no display
2) there might be posible Motherbord not getting power
Please check it - in a sequence
1) remove the RAM from the Motherboard -
2) remove the Hard Disk connection to the board
3) keep the VGA Cable connected (i.e Monitor Cable)
4) Keep Keyboad and Mouse connected
5) Turn On the CPU (Cabinet) by powering it
-- Check is there any disply on the screen ?
-- Checked is there any beep sound comming ?
If both are not there - ITS a SMPS Issue
if beep is there - and No Display - its VGA Connection issue
if beep is ther display is also there - turn off the CPU connect the RAM ad turn on - if display not comming after RAM Connection then the RAM is The issue
Then Check the HDD Connection -
I know it will be resolved
dont worry do it slow and check each bit and then apply
Jan 03, 2010 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Acer travelmate 290 beeping, starts with blue screen and then black and beeping
See if there is an error beep. If there is an erro beep, then change
main board.
Power off. Then check if RAM CPU BIOS are well-connected.
Press Fn+F5 three times slowly
LCD FPC
LCD inverter
LCD
USB does not work correctly USB device cable is firmly connected into the USB ports. Test
Oct 29, 2009 | Acer TravelMate 290 Notebook
Monitor display problem..
Change yor keyboard. If any one key remains pressd or if any pin is bent then evrything seems to work but there is no Display and no beeps or error messages either!......i too suffered the same once................sodeep
Mar 18, 2009 | Computers & Internet
HOW TO CHECK ASROCK MOTHERBOARD WARRENTY
»For Authorized Distributors Only: (Email: rma@asrockamerica.com)
»End users or indirect customer:
Thank you for choosing ASRock Motherboard. Due to the unique configuration of each computer, we recommend you to contact your dealer for technical support. If you would like contact us for technical support. Please send us an email support@asrockamerica.comand give us a detail discription of the problem alone with the following information.
  • CPU/Processor (Brand,Speed, FSB,Cache Size)
  • Memory (Speed, Capacity, Brand)
  • Video Card (Brand, Model, Memory size)
  • Operating System (Loaded service pack and driver)
  • Hard Drive (Brand, Model, Capacity)
  • Other Device (Brand, Model) * If necessary
*Additional system configuration information may require.
ASRock provide 1 year warranty service to Authorized Distrubitor ONLY, users should refer to the retailer or original vender RMA & Refund policy. For non Direct Customers, there is a $35.00 service charge + shipping for each item.
BIOS $15.00 + shipping
ASRock CD $5.00 + shipping
ASRock I/O Panel $5.00 + shipping
»ASRock Service Center (Brasil)
R: Andre Ampere, 153 -17 andar - SI173
Brookin Novo - Cep 0462-080
Tel/Fax: 55 11 5105-3137RMA Service: Email: rmabr@asrockamerica.com
http://www.asrock.com/support/index.asp?c=RMA
Dec 31, 2008 | Asrock 775i65G Motherboard
3 beep sound-no booting
system is on but no display. yes i did heard sound 3 beep sound from the motherboards.
Aug 16, 2008 | Intel D845GVSR Motherboard
P5b-mx
Is the CPU fan spinning? have you tried a different VGA card? (though if it's a brand new board, I'd be taking it back as it'll still be covered by the warranty)
May 29, 2008 | ASUS P5B-E Motherboard
Please help
if your cpu can't heat so your mobo vrm circuit fail ic no: adp3168 near by cpu
Mar 29, 2008 | Intel D845GVSR Motherboard
Satellite Pro 1905-S301
if u get normal beep of ram then check your disply resolution .
when u start your pc press F8 key continus then if u get menu choos best configuration loading in menu.then change your resolution to 800x600 or 1024x768 .if u not get menu and your cpu ;s smps still work but not disply on monitor then clear your bioss . get away the cmos cell for 15 minutes from its case.then start your pc .i think your problem is solved.
Mar 21, 2008 | Toshiba Satellite 1905-S301 Notebook
Monitor problems
Mar 20, 2008 | Computers & Internet
Asrock 775i65G Motherboard Logo
148 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
