First click on the Y= button and enter an eqation or goto stat and hit enter and type the points. Afterwards goto Y= then hit plot1 so it is highlighted and hit zoom and then zoomstat and you will have grphed your points.
You cannot have a scatter plot with just one variable. You need values in L1 and values in L2. If you have only one set of values you can do 1-var statistics and plot a histogram (x-value vs. frequency).
Your data must be in two lists L1 (for x-values), and L2 (for y-values). This is the default setting. Open the STAT utility, go to the regression models. Select your model then press ENTER. The command echoes on the main screen. For example let the regression be something called LinReg. On the main screen you see LinReg Complete the command line as follows LinReg L1, L2, Y1, ENTER You see the statistics including the regression equation. If you go to Y= Editor you will see that Y1 contains the regression equation. If you have already drawn the scatter plot for your data, pressing GRAPH will superpose the scatter plot and the regression curve., and you will be able to judge the goodness of the fit.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8. See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
You may have activated the dynamic graphing by running the Transfrm Application. If so, you must unload it from memory (this will not delete it from calculator)
Press the Apps key.
Use UpArrow (yes UpArrow) to scroll to the bottom of the list of applications.
Point to Transfm and press ENTER.
In new screen that displays, select the option that uninstalls Transfm.
