Question about Canon PowerShot SD600 Digital Camera
Inital picture playback showing too much info (histogram, etc)
I have the Canon Digital Elph SD600. Only problem I have is that right after you shoot a picture, during that 2 seconds you have to see it in the LCD screen, it is displaying a lot of "detailed" info with it, which gets in the way of seeing the pic. I can't figure out how to get it back to displaying only the pic and the "basic" info. They refer to "detailed" and "basic" info in the Advanced User Guide, but don't tell you how to switch it.
  • beachbum712 Mar 02, 2009
    I tried your first suggestion about repeatedly pushing display while it is showing too much info. It worked, and oddly enuf, the camera held that setting. I tried your second suggestion, but there is no "Custom Display" option in mine, at least I didn't see it. (only clock display) For now I seem to be good to go, and apparently when this keeps recurring, it is because someone has pushed the "display" button too many times while reviewing, and then that setting sticks until I change it back. Thanks!
  • beachbum712 Mar 03, 2009
    Great link.....better than the manual! Thanks!
    Novelist:
  • 98 Answers
There should a display button on the back side of the camera. Press the same repeatedly till you select the display you like. This would ne applicable when you are shooting or are reviewing the images.
For the review of the image right after you have shot, Go to the (Rec.) Menu> scrool down to >Custom Display> set button
Here you can set the level of information you want on the monitor, you can remove the tickfrom the information you don't require.
Let me know if you could manage to remove the unnecessary info...
Posted on Mar 02, 2009
  • Sachin
    Sachin Mar 02, 2009
    Dont worry it should hold.
    Most canon digital cameras have the custom display menu in the Rec mode. Let me check again and see whether the same holds good for Elph SD 600.
    Meanwhile Cheers!
  • Sachin
    Sachin Mar 03, 2009
    Go to link below..This is a review of SD 600. It clearly explains how to do settings both in Rec mode as well as playback modehttp://www.imaging-resource.com/PRODS/SD...
    Hope the same is useful.
    Enjoy
How can i get the great picture in my canon 60D camera
one way is use the histogram on rear screen,find by turning screen on then press info button until histogram appears.it looks like a small moving mountain .mid is average left is darker right is brighter.i find slighty right of centre gives good results then fine tune.and shoot raw format then post process on canon digital photo pro.never use auto setting.i use av mode .f5.6 low light or blur and f10 landscapes.hopes that helps for a start
Apr 25, 2016 | Canon Cameras
I cannot take photos when i shot with manual mode.The shutter clicks but no picture is actually taken.Darkness.The auto mode works fine.Lens Nikkor Micro AF-S 105mm.Drives me crazy
When you shoot in manual mode, make sure your camera sensor gets enough light. When you shoot inside with dimm light at 1/1000 of a second or faster and a aperture of 8. all pictures will be black.
The best way to learn shooting in manual, is to shoot a picture in the P mode and put the picture on the screen (>) button. then select the info, where you see time, aperture iso and so on. and even better select the histogram. Note the figures in your head (or on paper) and then goto manual and make sure you have almost the same settings. Then shoot en look what the histogram shows. No histogram on the right, means to little light, so lower the shutter speed, open the diaphragm or increase the ISO. No histogram on the left, means to much light, so higher shutter speed, lower ISO or smaler diaphragm (the aperture number must be up. 3,6 is wide open 16 is almost closed.
Mar 14, 2015 | Nikon D7000 Digital Camera
How do i remove the histogram from my lcd screen?
While viewing the picture, press the INFO button to cycle through the various available views. See the "Image Playback" section of the instruction manual (page 71 in my copy). If you need a copy, you may download it from here.
Jan 18, 2013 | Canon EOS 600D Rebel T3i Digital Camera...
Canon SD600.. Can not select date stamp on
This link will be helpful for you. Scroll down and you'll see date stamp along with pictures.
http://www.imaging-resource.com/PRODS/SD600/SD600A3.HTM
In case of further help let me know
Mar 25, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cannot remove the histogram display after picture is taken
there is a button on the back DISP.
PRESS ONCE OR MORE TO CYCLE BACK TO RIGHT DISPLAY CHOICE...
Apr 06, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
I have a Canon PowerShot SD600 Digital Elph, and the screen on the back has turned off while I try to take a picture. It will show on the screen when I try to take a movie, but the photos is just a black...
Did you accidentally hit the DISPLAY button on the back of the camera. It turns the LCD screen on and off in picture mode to save batteries.
Jun 23, 2008 | Canon Cameras
Help! Dropped my Candon Powershot SD600 Digital Elph.
replace the motorized lens and you should be ok. You have to buy a duplicate Parts camera from Ebay to have the part to fix yours.
Mar 15, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Stuck in movie mode, but won't record
internal microswitch connector has been damaged.so it has been stuck at movie mode ,it can be replaced.
Mar 06, 2008 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
