Question about General Electric JBP22B Range
Stove top burner won't heat
General Electric JBP220J3AD Electric Range. 8" burner coil shorted out. Replaced coil, but it still won't heat.
5 Suggested Answers
  • 2841 Answers
SOURCE: WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Posted on Apr 25, 2010
  • 314 Answers
SOURCE: oven was working before breakers were turned on
make sure that the stove is gettingn power 110 volts
Posted on Sep 07, 2011
  • 3 Answers
SOURCE: How do I plug back in the GE stove top burners after unplugging them?
The two leads from the burner fit into a socket in the stove top. It's a bit tricky to get it in just right. If the three metal "legs" on the burner fit snugly into the three slots on the stovetop you did it right.
Posted on Aug 27, 2012
TheMobilian
  • 8220 Answers
SOURCE: OVEN TURNS OFF WHEN I TURN ON THE THE TOP BURNERS- ELECTRIC STOVE
That to me sounds like a breaker going bad in the electrical service panel. Probably nothing wrong with the stove.
Posted on Nov 21, 2012
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Aug 26, 2012 | General Electric Ge Stove / Oven / Range...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
8'' electric stove top element not working
timer on what ? make, model and age of unit might be useful in forming a coherent response.
Mar 07, 2017 | General Electric Stove/Oven/Range Chrome...
Front Right Large Burner Wouldn't Boil, Now won't heat at all
The burner has a short now. The burner is a resistor and when it is shorted the burner will not heat to its full capability. You should be able to replace the burner element. Home Depot or Lowes may have the part you need or you can most likely get them from Amazon. They have everything.
Cheers
Nov 26, 2017 | General Electric Stove/Oven/Range Chrome...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
36" electric top coil stove.
This sounds like a short somewhere in the unit to ground.  I suggest you get professional assistance.  This could be hazardous.
Sep 25, 2008 | KitchenAid KESC307 Electric Kitchen Range
General Electric JBP22B  Range Logo
Top General Electric Kitchen Ranges Experts
Craig Butler
Craig Butler
reliableservice
DROPNDEAL
DROPNDEAL
Are you a General Electric Kitchen Range Expert? Answer questions, earn points and help others
