Question about Autodesk AutoCAD 2004 for PC
Windows vista will not open autocad 2004 after being loaded
IN THE PROCESS OF LOADING DISC IT STOPS AND COMES UP WITH A ERROR MESSAGE THAT READS PLEASE RESART AN TRY AGAIN WHEN YOU PRESS OK AND THE MASSAGE GOES AWAY AUTOCAD THEN SAY'S IT AS COMPLETED SUCCESFULLY PRESS FINISH WHEN YOU DO THAT THE ICON APPEARS ON TH DESK TOP BUT WHEN YOU DOUBLE CLICK ON IT,IT COMES UP WITH AUTOCAD HAS A PROBLEM TRY AGAIN
  • ispencer500 Mar 09, 2009
    I have a similar problem with AutoCAD 2005. It appeared to load from the original (Genuine) CD onto my new PC running Vista Home Premium (Genuine) but then will not run.
    I have followed the advice noted in various threads to run AutoCAD in XP Compatibilty Mode and as Administrator. HOWEVER, when I right-click the executable file (acad.exe) I do not get the Compatabilty Tab.
    Can anyone help please?
  • Anonymous Apr 28, 2009
    same problem !!!
Installing autocad 2004 on Vista windows, while loading disc stops, Error MS 19725
Posted on Aug 24, 2010
All you need do is got to autocad website and download the autocad lockeds1. its a patch it works for pirated autocad as well.
Posted on Apr 30, 2009
Check out the posts at: http://discussion.autodesk.com/forums/message.jspa?messageID=5492130
they are old (circa 2007), but seem to list a reasonable solution for those of us that can't afford newer versions of ACAD. Please note, I haven't tried this! I'm purchasing a new machine currently and am looking for options and potential problems in transferring programs.
Please provide feedback!
Posted on Mar 08, 2009
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
Autocad 2004 and win vista
Apparently, autocad is not compatible with vista.. Might as well, go back to wndows xp.. Please see the required specs to run autocad 2004
Mar 22, 2010 | Autodesk AutoCAD 2004 for PC
Load dvd disc, dvd reads disc then comes up with
I am just wondering whether the unit has got condensation inside.
Just try to do this as a process of elimination.
Take the dvd and place in a warm room.Plug it into the mains (try and eject disc if not leave in) and leave for 2-3 hrs
Give it another try..fingers crossed.
Dec 04, 2009 | Panasonic DMRES15 DVD Recorder
Autocad 2010 problem
If you run Win7 in XP mode, all should be fine.
May 06, 2017 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
Autocad in vista
Installation process of all softwares are same (The wizard format) except if you are getting any error message.
Aug 30, 2009 | HP Pavilion dv4000 Notebook
AutoCad R14 to Vista - bab-Mem-Pointer error message
You are still using AutoCAD R14? If you are that might be the problem. If you are running Vista, then AutoCAD R14 might be too old of a version to run. You will probably need to upgrade to a newer version of AutoCAD. I know this isn't a solution, but I am just trying to look at it from a different point of view. You can also go to autodesk.com and join their discussion groups. It is free and you can post questions. You usually get a fast response with an answer that really helps. I will do a little more research and add more when I get a chance. Good luck and I hope that I helped.
Feb 22, 2009 | Autodesk AutoCAD LT 2008 - Upgrade for 5...
Conflict with Autocad 2004 (using Windows Vista)
Autocad 2004 is designed to be used with Microsoft Windows XP (Professional, Home Edition, or Tablet PC Edition), Windows 2000 Professional, or Windows NT 4.0 (SP6a or later) therefore I'd suggest to run your Autocad 2004 using Compatinity Mode --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
May 23, 2008 | Autodesk AutoCAD 2004 for PC
Autodesk AutoCAD 2004 for PC Logo
2,038 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
