Had locksmith replace key and tumbler in car. Did not replace front properly. Husband tried to fix it and a spring switch located above the key and tumber toward the back sprung out and was lost. Affects the clock, interior lights, automatic key lock and alarm cannot be set, license plate lamp, automatic trunk opener, none of these now work.Want to replace but do not know the part to order and have been unsuccessful looking for it.
SOURCE: keys lock in trunk alarm will not allow trunk switch to lock
The solution is to pull out the back seat to get into the trunk. There are two bolts holding the bottom part of back seat (bolts located between bottom and top sections). Then pull out bottom section of back seat and you see the hinge for the top section, remove the bolts and then you can lift up and access the trunk. It's not that hard.
SOURCE: The keys are locked in the trunk. a lock smith
Remove the back seat. Back seat has two parts, bottom section that you sit on and back section. In between the bottom and back sections there are two bolts, feel for them and then remove. Once removed the bottom section can be pulled out. Then you can see the hinge at the bottom of the back section, remove bolts at the bottom and then you can lift up and access the trunk.
