Question about Audiovox Jensen Waterproof Gimble Mount Radio Housing With Ipod Pocket
Water entered my i-pod and now it isn't working.. it only shows the apple symbol when i charge it.
    Problem Solver:
  • 6 Answers
It happened to me too. Dry it up with a blow dryer before trying to power it up. but it probably was not a good idea to power it on before completely drying it.
Posted on Mar 02, 2009
With I pod dock won't play latest apple products I have used an adapter from old fitting to latest fitting and it shows it charging but will not play tunes
This is normal. The adapter will only allow ''charging.'' The new Apple product is not compatible with older (non genuine Apple) docks and accessories. And even with ''genuine'' Apple, older units may not work with an adapter. With genuine older Apple products you can check with Apple what will work with an adapter.
Ps... Even the _adapter_ needs to be ''genuine'' Apple. Most of the time, ''charging'' is all you will get from generic adapters.
May 18, 2015 | Wurlitzer Jukebox 1015 One More Time...
My i pod only shows apple logo what to do ?
Not really working is it? Firstly the charging port
is probably broken,or the connector to it is.Another connector
the cheapest for that,but a waste of money if not that.Your
other problem may be and l say maybe fixed once charged.
Failing that,it will be the shop for a proper fix.
LUCK
Oct 03, 2014 | Apple iPod touch
What's your problem?i have a apple 80 gb ipod and i dont know if this thing is charging
Plug the charger into a USB port or wall charger. Then plug the other end into your i pod. Once plugged in and successfully connected to power then a green battery symbol should appear. If not then their might be something wrong with the power supply or the i pod.
Sep 03, 2012 | Apple iPod classic 6th Generation Digital...
My ipod wont show on the computer but will charge?
If you want the i-pod to,I hope you have I-tunes software and a cable for your I-pod.
Of you don't have I-tunes, you can install i-tunes from I-tunes website
: www.apple.com/itunes/
You can get a detailed information on how to put song on your
i-pod from the link below.
http://www.wikihow.com/Upload-Songs-to-an-iPod
I wish you good luck.
Mar 17, 2010 | Apple iPod shuffle MP3 Player
My i pod screen went black you can still see a little but i cant get it to brighten
Try the following
Turn the ipod off and then on again.
If that does not work reset the ipod while it is connected to the power. You do this by pressing and holding the sleep/wake button and the home button at the same tme for at least 10 seconds, until either the apple logo or battery symbol appears. If the battery symbol appears, charge the ipod until it is fully charged.
Hope this helps.
Nov 14, 2009 | Apple iPod touch
The i pod is not showing that it is charging
Since it has been sitting for so long, try doing this: Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge just enough so that it can sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, charging. It should work after letting it sit plugged up to the computer.
Dec 30, 2008 | Apple iPod nano
Ipod Touch 8gb problems
Hi K,
Ahhh, everything has suddenly become very clear :) All is well and there is nothing wrong with your ipod. Heres what you need to do.
  • First, install the very latest version of iTunes onto your PC or Mac - Download it from http://www.apple.com/itunes/download/
    Tip: Uncheck the two boxes and don't enter your email address
  • Once that's installed, start iTunes up and connect your iPod to the computer via a USB2 port (any on a laptop but not through a hub; on a PC tower use only one of the USB ports on the rear of the machine, ie, none of the ports on the front) - It's gonna need charging (That's what the Batt symbol is showing) so leave it for a good 2hrs.
  • While it's charging I'd recommend spending some time familiarizing yourself with the user guide - it explains alot of these symbols and more importantly how to get started with your new iPod. You can download the manual from here: http://support.apple.com/manuals/#ipodtouch
  • When it's good and charged then follow the onscreen instructions for the iPod on iTunes. You have to register the iPod first before you can use it. So once you've done this all will be well in the world for you. See page 5 and 6 of the manual.
All the best
Sean
PiDigital
Dec 27, 2008 | Apple iPod touch
My i pod has frozen
First thing you do is to switch the hold button on then off, and then when the ipod is not on hold you press the center button and the, and the play/pause button at the same time. then hold on to them two buttons to where to ipod symbol shows up. then you wait and it will go back to normal!
Nov 30, 2008 | Apple iPod nano
Apple 20gb Ipod Mp3 Player
your battery has come to its end of shelf life.
buy new battery on e-bay...open i-pod insert...
charge for 3 hours...problem solved!!
battery will cost £6 on ebay uk
May 20, 2008 | Apple 20gb Ipod Mp3 Player With Click...
Chinese I pod not working
try to use itunes software
Mar 06, 2008 | Audio Players & Recorders
Audiovox Jensen Waterproof Gimble Mount Radio Housing With Ipod Pocket Logo
52 people viewed this question
Top Audiovox Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Audiovox Boating Expert? Answer questions, earn points and help others
