Question about ASUS P4S8X-MX Motherboard
Upon switch on, it takes several minutes or more or less 15 minutes to load personal setting
  • Tim Crosslin May 11, 2010
    What operating system are you using?(i.e. Windows98/2000/XP/Vista)
    How much RAM is in the computer?(i.e. 128MB/256MB/512MB)
    What processor are you running?
  • 505 Answers
If you upgrade to more MEMORY RAM you load time will be much faster
Posted on Mar 09, 2009
Reset my kindle,
Dead battery. If you haven't charged it for several years it dies.
Unreparable although if you call kindle customer support they may give you a discounted price on a new or refurbished current model Kindle. They'll want your old one for parts.
Jul 02, 2015 | Tablets & eReaders
The start/pause switch on my washing machine is not working properly, its like the spring has broken on the back, the panel was replaced a few years ago for the same problem, is there a way of fixing
It does sound as if it is the switch, since you can eventually get it going. Depending upon the age of the washing machine, you will need to decide whether another repair bill is worth it. I would look at the last bill and call the repairman for an estimate of current charges if you are sure it is the same problem. I don't recommend attempting ANY repair by an unauthorized person to a major appliance. Good luck to you.
May 20, 2014 | Hotpoint Aquarius WF220 Front Load Washer
Just start 15 minutes and then stop
Pull the cover if necessary to see if the fan is spinning. If it's running 15 seconds, your door switches are probably ok, and the touchpad is working, main fuse ok. All that leaves is the circuit board and the magnetron.
Personally, I prefer microwaves with twist timers, not touch pads. A lot less to go wrong.
Nov 22, 2013 | Panasonic NN-S969 Microwave Oven
I need instructions on how to set my Grasslin Intermatic FM1 STUZH 120 timer
Open following links for analog timer instructions:
FM1STUZH-120 is 120Volt 24 hour timer with manual override button.
Each tripper-or-pin on timer dial represents 15 minutes.
The timer can be set for several different purposes.
Since the timer has manual override and NO NC terminals, the best way to proceed is to wire your timer, turn power ON, move 10 trippers-or-pins outward, leave rest of pins inward, then manually rotate dial to watch when load turns on-off. Then move override switch to each of 3 positions and repeat same test.
These actions will reveal correct wiring and switch setting for your purpose.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 05, 2011 | Intermatic FM1STUZH-120U - 24 Hour...
We had a power outage last night and I have not been able to successfully restart my 3Com V3000 server. I have powered it down several times, waited several minutes before restarting, but it just shows...
After you power it up LEAVE IT ALONE for at least 45 minutes. When the NBX loses power abruptly it will do a disk scan upon reboot. The disk scan takes anywhere from 15 minutes to 45 minutes (depnding on the size of the database). You can connect to the console and see it doing a disk scan when you boot it back up. It will go through 6 phases and then boot up normally. Each time you pull the plug you risk database corruption (or hard drive failure on an older system).
Aug 05, 2010 | 3Com NBX® V3000 (3C10600BUS)
Is my inverter working correctly?
An inverter should work immediately.
Jun 10, 2010 | Electronics - Others
The blower fan comes on several minutes before the
Bad fan switch. It may also be called a fan limit switch. If your furnace is less than 5 years old, the switch is part of the circuit board and you will need to replace the board.
Jan 11, 2010 | Heating & Cooling
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
My 7.75 Hp snowblower starts, runs 15 minutes, then stops.
check your eingine compression, sounds like it is worn hence the rough idle and loss of power under load
Jan 29, 2009 | Briggs Stratton H7159 & Stratton® 5500,...
Loading XP 15 minutes into the load it stops
100% free, but 100% qualfied experts to help you.
Oct 31, 2007 | Dell Latitude D600 Notebook
ASUS P4S8X-MX Motherboard Logo
50 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
