Question about Zenith C34W37 34" TV
Won't turn on - relay clicks, power supply squeals, relay clicks, etc,
Hello -
The boss just brought in his Zenith C34W37 television. When I plug it in, I hear it de-gausse (sp?), the relay clicks on, I hear the switching power supply squeal for a second or so, the relay clicks off, then on again, the power supply squeals again, and that repeats as long as the TV is plugged in.
I don't see any obvious bad caps, but I haven't really tested anything yet. To me, it sounds like something is shorted, but I don't know where to start.
Any input would help!
TIA - Mark same problem relays click and volume comes on loud no picture and can't control anything.
  • Dante Reopelle Mar 02, 2009
    this is a flat screen would that be any different do you think? Now do I just unsolder the hot wire from where it connects to the hvt?
    Thanks for your help!
    Novelist:
    Scholar:
  • 95 Answers
The television has a protection circuit. Sound like you know something about electronics so that is cool.
I suspect the HOT or High Voltage Transformer. If you want to operate on it, they typically will short externally from moisture or plastic high voltage breakdown. The TV starts, shorts as it cannot come to full high voltage, then shuts down. If your brave, you can unsolder the HOT which is the part that is on the main board or that comes from the top of the picture tube wire into a dark or spaceship type object.look underneath, sometimes they short underneath and you can scrap the carbon and get it to at least start up and work. Do not leave this as a fix as it can be a fire hazard.
The HOT is the most common. They are around 20-60 bucks. 34" TV. I am assuming this one without looking it up it is NOT a flat screen, as most do not squeal like that nor do they have to de-gausse like the old ones. I just looked it up and yes it is not a flat screen. Old school, so that is more thank likely the problem.
Posted on Mar 02, 2009
TV will not power up
These flat panel Tv's, all of them, sometimes have cheap Capacitors in the power supply section. They'll keep tv off and tripping relay circuits. It's not a fault in the power supply ic's, it's a fault in the main Capacitors. The IC thinks there is a leak, so it shuts down tv. It monitors voltages through comparators, and compares them to reference voltages. So check main power Capacitors and replace as needed. A lot of Chinese made Capacitors are cheap. In the big sets, they break down a lot.
Jan 15, 2014 | Zenith Z50P3 50 in. Plasma TV
Colors on screen are warped like a rainbow. What may it be?
This is called gaussing, and is often caused by a magnet being too close to the screen. Unfortunately, most TVs do not have a de-gauss setting to reverse it.
Sep 12, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
42HDS69 On off switch won't work sometimes
The clicks are coming from a mechanical relay in the standby supply for voltage---the standby power supply runs 7/24 if set is plugged into power.
What I would do if you are able is open set and on power board (power cord goes to it) look for and replace any filter caps that are puffed up there--the relay is possible but rarely bad in this way unless a solder connection under it is bad.
If caps are good you have a connection or bad part near the relay that likely is causing this problem.
Look closely at filter caps in power supply:
even one that is slightly puffed up can cause this, if find that and need to know what and how let me know.
Dec 19, 2012 | Hitachi Televison & Video
My Vizio VX37L HDTV won't turn on. Was watching it one day & it turned off by itself. Replaced power supply with new one with no luck. Orange light comes on but will not turn white.
reset the tv with the tv off, but plugged in hold down the soarce botton on the tv for 5 seconds it should click on and work. if not then there may be curcuit board issues. i found the same tv on the side of the road as somewone was throwing it out, it was leaning aganst their trash can. i brought it home. plugged it in and it went on and inediatly went to the orange vizio light. i rest it and it's been perfect ever since is my comoute monitor now...good luck i hope that fixes it for you..
Nov 25, 2012 | Vizio L37 Television
Zenith Z50PJ240 powers on and turns off relays click while its doing this unplugged ysus and zsus no change unplugged comp board tv turns on red light goes out but will not power down then.
It becomes first a case of checking voltages to and from power supply first and then a guessing game---which board will you buy and try first?
Nov 06, 2012 | Televison & Video
Zenith a27b41w won't turn on. It just clicks whether using the remote or the button on the tv
Probably a power supply problem. The click could be a relay closing
Nov 04, 2012 | Televison & Video
When i plug in my tv i hear clicking in the back and won't turn on. what could be wrong? thanks
Its a relay that cliking at the board.Theres a short circuit parts that may cause of relay on and off funtion thats why your Tv have no power.So Its better to repair and troubleshoot the power supply of your Television.
Jul 17, 2011 | Televison & Video
I HAVE A MATSUI 28WN20 CRT TELEVISION AND ITS COLOUR HAS TURNED REALLY WEIRD. FOR EXAMPLE BLOOD SPLATTER COMES UP AS GREEN AND ALL THE REST OF THE COLOURS YOU SEE ARE ONLY PURPLE AND GREEN .
Hi, this sounds like your TV needs De-Gaussing, the screen has become magnetised and the electrons being fired at the screen are being diverted or scattered and mixed to the area's that are magnetised creating the odd colours, what you need is a de-gaussing coil, you can wave this in a pattern to de-magnetise the screen thus allowing the electrons to flow properly to the screen, it may also be the PTC on the tv's PCB near the mains input, if this is faulty the tv's own degaussing coil may not operate properly, you local TV technician maybe able to help with this as the part is specific to the TV, they maybe able to degauss it too for a small fee.
Here's a better expaliation ---> CLICK HERE <---- it shows a circular pattern here but there are many kinds of pattern magnetism can create but the colours are nearly always the same just in different places witn different strengths.
Hope this helps.
Feb 11, 2011 | Televison & Video
The screen is green all around and the middle is purple.
This is case of colored patches due to magnetic field,check and remove any magnetic thing close to the set, if the same problem is seen than switch off the set by main ON/OFF and switch on after about half hour,if still the problem remains than replace PTC used for de-gaussing,connected with de-gaussing coil mounted around the picture tube i.e electrically removes magnetic field every time TV is switched on.
Feb 06, 2011 | Sony KV-20TS32 20" TV
Open Questions:
Zenith C34W37 34" TV Logo
471 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
