Question about Canon NP 6545 Copier
Feeder will allow copier to setup to copy
When I Turn on Copier send error Message of E540A switch the power off and on again
  • 2 more comments
  • michael donaldson Mar 02, 2009
    canon np 6545 copier is not hooked up to a pc sends error code E540a Switch the power off and on again
    how to do hard reset
    the top two dont move (trays) then go into error mode
  • cool fixya
    cool fixya May 11, 2010
    Press (Additional Functions *) 2 & 8 simultaneously, (Additional
    Functions *). You have now entered Level 1 Service mode. Select
    Copier>Function>Clear>Err>OK. That is a hard error reset.
    Next hit reset until you're back at the main screen, or if you're in an
    error condition, the error screen. Power off and then on. If it's a
    clearable error, your machine will come back up. If there's a hard
    error that needs attention, you'll probably get the error screen back.
  • 82 Answers
Press (Additional Functions *) 2 & 8 simultaneously, (Additional Functions *).
You have now entered Level 1 Service mode. Select Copier>Function>Clear>Err>OK. That is a hard error reset.
Next hit reset until you're back at the main screen, or if you're in an error condition, the error screen. Power off and then on. If it's a clearable error, your machine will come back up. If there's a hard error that needs attention, you'll probably get the error screen back.
Posted on Mar 02, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason to this error problem is the
lateral movement motor lock.This is the
problem with error E540A.
check this out..
thank u..
  • Hariharanath V Mar 02, 2009
    hi..press* PRESS 2 & 8 AT THE SAME TIME,PRES*
    DISPLAY WILL NOW SHOW CHOICE OF COPIER,
    FEEDER,SORTEROR BOARD MODES,LEVAL 1
    PRESS "RESET"TO RETURN TO PREVIOUS SCREEN.
    PRESS"RESAT"TWICE TO EXIT.
    thanks..
    ya that error is due to lateral movement motor
    lock.you have to check it out.
    thanks..
  • 744 Answers
Hi it is clear that is a fuser realted issue.... Not warming up properly...
Most likely a defective fuser. The over heat has opened, the heat element has gone bad.
Fuser more then likely needs replaced... so go for a replacement of fuse..
thank u!!!
  • 523 Answers
This Error means there is something obstrucking the finisher from moving up and down? check the finisher if there is anything locking it, or check the trays if they are moving or not, somthing locking the finisher trays.let me know what happen.
Best Regards
  • Kyocera HP Expert Mar 02, 2009
    Is the sorter tray looking from the front veiw crooket or bend? if yeah you have to readjust the cam to make it straight, this code is 100%  a sorter problem.
    Brigadier General:
  • Canon Master
  • 3,614 Answers
do a hard reset on the machine unplug the unit for 8 hours.
let me know
  • 564 Answers
  • Unplug the Copier cable from the computer.
  • Unistall the Copier drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the drivers and software it will ask you to connect the copier.
  • then you can connect and test it.
Hope this help. Please Rate My Response! Thanks!
Prem
When scanning it gives error of deleting
are you using your phone and or Ipad to control the document feeder what do you mean operating remotely???????????? turn off the main power switch??????????????????
Mar 26, 2014 | Konica Minolta Bizhub C454 Color Copier
Clc color copier error code E061-0321
Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
1) A solid black copy means laser is defective.
2) A white copy means you should check the Primary corona and HVT.
3) A good copy means you should check the Potential sensor PCB.
Dec 01, 2012 | Canon CLC 4000 Copier
What is network error (CE 03)
There is something not setup at all on the webpage or setup wrong on the webpage of the copier to allow you to scan to email. Need an IT guy make sure that your SMTP, DNS and reply address are correct on the webpage of the machine.
Nov 01, 2011 | Sharp AR-M455N Copier
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
Getting e711 error message, requires restart and still gets same error
There is a communication error between the machine and one of the accessories.
Turn the copier off, disconnect all accessories (sorter, feeder) and try again.
You may want to reconnect them one at a time to see which one is bad.
Nov 12, 2009 | Canon NP 6230 Copier
Bizhub C650 (Minolta printer, copier)
setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Oct 13, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Canon copier np 6545
E540 is a sorter/collator problem
You can unplug the sorter and move it away from your copier then swith off then on again and the copier will work and you can still sort via the document feeder.
here is the error code disription...
E540
Cause..
• Bin shift motor (fails to rotate)
Discription....
• The operation does not end within a
specific period after the motor drive
signal has been generated.
• Clock signals from the clock sensor
of the motor are absent for a
specific period.
• The input signal from the lead cam
position sensor does not change for
a specific period.
Jun 08, 2008 | Canon NP 6545 Copier
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Error - E401
e401 on a 6545 is the RDF (reversing doc feeder) pick up motor or pick up sensor problem. Does the rdf attempt to pick up the original or do you get the error as soon as you press start? Are you aware of how to remove all the rdf covers? The pick up motor has a timing wheel & sensor that need to be periodically cleaned.
Jan 22, 2007 | Canon NP 6545 Copier
Canon NP 6545 Copier Logo
29 people viewed this question
old marine
old marine
